    Last update - 3.5.3 - File simulation runs infinitely
    Duet Web Control
    • EagleB3undefined
      EagleB3
      After upgrading from version 3.5.2 to version 3.5.3, the file simulation process runs infinitely. My configuration after upgrade:
      As usual, I start the simulation process for a part that was previously successfully simulated in version 3.5.2:
      After a while, a pop-up window about the end of the simulation process with information about the results is shown at the bottom of the screen.
      After a while or by clicking the mouse, the window is hidden - up to this point, everything works correctly.
      But after that:
      1. The screen says that the simulation is 100% complete
      2. The "Pause Simulation" button is still displayed, which should only be displayed during the simulation process.
      3. The "Slicer" counter continues to count down, its value continues to decrease.
      4. The "Current Layer Time" counter continues to count, its value continues to increase.
      5. The "Job Duration" counter continues to count, its value continues to increase.
      If you go to the "Jobs" section at this time, you cannot start the simulation of another part by right-clicking.
      • chrishammundefined
        chrishamm administrators @EagleB3
        @EagleB3 Please share your config.g and the job file.
        Duet software engineer
        EagleB3undefined 1 Reply Last reply Reply Quote 0
        • EagleB3undefined
          EagleB3 @chrishamm
          @chrishamm , Thank you! Here is a link to my config file and Gcode file
          The process of printing the part is carried out absolutely normally, the process is completed without any errors.
            @EagleB3 Thanks for reporting this, I can confirm this problem. We're working on a bug fix.
            • EagleB3undefined
              EagleB3 @chrishamm
              @chrishamm , Many Thanks!
                dc42 administrators @EagleB3
                @EagleB3 I've created this issue https://github.com/Duet3D/RepRapFirmware/issues/1049 and I've put a fix in the source code. Please try the new MB6HC binary at https://www.dropbox.com/scl/fo/7gp2oap68w5rrkq2x8hmi/ACeGHn8KsOTMvUYRgWaGuFc?rlkey=8tpn91e05flw89xbzomj2b05g&dl=0.
                dc42 created this issue in Duet3D/RepRapFirmware
                closed Simulation doesn't complete in RRF 3.5.3 #1049
                • EagleB3undefined
                  EagleB3 @dc42
                  @dc42 , After installing the new MB6HC binary from the link you provided, the problem was completely resolved. THANK YOU SO MUCH!
                  • dc42undefined dc42 marked this topic as a question
