    [3.6.0-beta.1] Head crash after resume on a delta
    Beta Firmware
    238
    • balajiramaniundefined
      balajiramani
      I paused a print and tried to resume it and the effector moved in a "U" shaped move when resuming the print. Due to this, the nozzle crashed into the printed part and messed up. This is on a delta printer.
      I am attaching config.g, pause.g and resume.g.
      Thanks,
      Balaji
      balajiramaniundefined 1 Reply Last reply Reply Quote 0
        balajiramani @balajiramani
        @dc42 were you able to look into this issue?
          @dc42 any update on this?
            dc42 administrators @balajiramani
            @balajiramani this may be resolved in 3.6.0-beta.2. Please test again using that version. You may find these files useful for testing, they describe circles at 2mm and at 50mm height above the bed.
            circleHighDef-2mm.gcode circleHighDef-50mm.gcode
            You may also wish to try the 3.6.0-beta.2+4 build at https://www.dropbox.com/scl/fo/ga0jqwfksechhukg2uiz8/AOV3DR8z1C0UWczc8Rx25gE?rlkey=4saeh9luddndvxbhb0kdaqugr&dl=0.
              balajiramani @dc42
              @dc42 I uploaded the 3.6.0-beta2+4 build an changed the height from 50mm to 10mm to as it would be easier to see if the problem occurs. When pausing, the effector moves in a straight line, but when resuming, it moves in a 'U' shape. I am attaching a video that shows that.
              PXL_20241205_050140998.TS.mp4
              dc42undefined 2 Replies Last reply Reply Quote 0
                @balajiramani thanks, I will look into it.
                  @balajiramani is your board a Duet 2? I think I've spotted the cause, but it only affects Duet 2 boards.
                  [EDIT: from your config.g file I think it is.]
                    balajiramani @dc42
                    @dc42 Yes, it is a Duet 2 Wifi board.
