Failed to retrieve WiFi status message
Duet Web Control
  • undefined
    DonStauffer
    Had an internet problem, so I cycled the power on my router. Internet is up again, but the PanelDue flashes this message over and over and the DWC won't connect. I'm in the middle of a print, so I can't cycle the Duet 2 WiFi (3.6.0 alpha 2 I think) power right now. I hope this message being repeated constantly doesn't eventually crash the Duet. I don't see a way to stop it. This is a bit concerning since I have no emergency stop except turning the power off.
    https://drive.google.com/file/d/1LCv6xmfYNOJrZTD_DPjfoaHpMnVHaB1b/view?usp=sharing
    undefined 1 Reply Last reply 21 Oct 2024, 23:58 Reply Quote 0
    • undefined
      droftarts administrators @DonStauffer
      @DonStauffer You could connect via USB while the printer is running, and turn the WiFi off and on with M552 S-1 then M552 S1. Otherwise I think it will be fine to leave it until the print finishes.
      1 out of 2
