    raspberry pi 4 and 6HC firmware not matching
    Firmware installation
    • darylpriceundefined
      darylprice
      I am really new to these boards, so some of my questions I am sure have been answered before.
      As stated above the firmwares for the PI 4 and the 6HC are not matching. I have tried every different combinations.
      Here is my procedure:
      1. First I am unable to connect to the pi through SSH (do not know why yet)
      2. I am using raspberry pi imager to move the file "image_2024-09-19-DuetPi-arm64.zip"
        a. I have added to the cmdline.txt file
      3. I am using DWC to upload the the 6HC file name: "DuetSoftwareFramework-3.5.4.zip"
      That has been my process below is what I get out of M122 when sent from the DWC
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.4.6 (2023-07-21 14:11:38) running on Duet 3 MB6HC v1.02 or later (SBC mode)
      Board ID: 0JD2M-9P9DA-F0PSD-6J1F6-3S46Q-14SM2
      Used output buffers: 1 of 40 (13 max)
      Static ram: 153252
      Dynamic ram: 65240 of which 0 recycled
      Never used RAM 132180, free system stack 219 words
      Tasks: SBC(resourceWait:,0.5%,486) HEAT(notifyWait,0.0%,371) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,943) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,343) TMC(notifyWait,7.3%,92) MAIN(running,92.3%,1126) IDLE(ready,0.0%,30), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:29:17 ago, cause: power up
      Last software reset time unknown, reason: HardFault undefInstr, GCodes spinning, available RAM 132328, slot 0
      Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00010000 ICSR 0x0044a803 BFAR 0x00000000 SP 0x20423f48 Task CanR Freestk 622 ok
      Stack: 400e0c00 5a000013 00000000 00000000 204241d8 00481675 004aa808 21070000 20423fdc 00000003 20423fdc 204354a8 0048257d 00000003 00453523 2042ac48 0000fddc 204354a8 00449f63 204354a8 878541e5 dfff8386 7e7dffff ffff797f ffffffff ffffffff ffffffff
      Error status: 0x00
      Step timer max interval 134
      MCU temperature: min 35.4, current 42.9, max 43.2
      Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.3, max 12.5, under voltage events: 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min n/a, mspos 8, reads 29935, writes 0 timeouts 0
      Driver 1: standstill, SG min n/a, mspos 8, reads 29935, writes 0 timeouts 0
      Driver 2: standstill, SG min n/a, mspos 8, reads 29935, writes 0 timeouts 0
      Driver 3: standstill, SG min n/a, mspos 8, reads 29935, writes 0 timeouts 0
      Driver 4: standstill, SG min n/a, mspos 8, reads 29936, writes 0 timeouts 0
      Driver 5: standstill, SG min n/a, mspos 8, reads 29936, writes 0 timeouts 0
      Date/time: 2024-12-24 16:43:01
      Slowest loop: 0.90ms; fastest: 0.03ms
      === Storage ===
      Free file entries: 10
      DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Segments left: 0
      Movement lock held by null
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === CAN ===
      Messages queued 8187, received 0, lost 0, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 8187/0/0
      Tx timeouts 0,0,8187,0,0,0 last cancelled message type 30 dest 127
      === SBC interface ===
      Transfer state: 5, failed transfers: 0, checksum errors: 0
      RX/TX seq numbers: 2481/2481
      SPI underruns 0, overruns 0
      State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2ab5c
      Buffer RX/TX: 0/0-0, open files: 0
      === Duet Control Server ===
      Duet Control Server version 3.5.3 (2024-09-19 12:16:06, 64-bit)
      HTTP+Executed:
      Executing M122
      Code buffer space: 4096
      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
      Full transfers per second: 39.39, max time between full transfers: 40.6ms, max pin wait times: 32.5ms/4.7ms
      Codes per second: 0.29
      Maximum length of RX/TX data transfers: 3380/272
      Phaedruxundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        Phaedrux Moderator @darylprice
        @darylprice said in raspberry pi 4 and 6HC firmware not matching:
        You should be updating the Pi from the pi terminal and sending sudo apt update && sudo apt upgrade but if you can't reach it via SSH you'll have to solve that problem first.
        https://docs.duet3d.com/en/User_manual/Machine_configuration/SBC_setup#update-firmware
        You can also force the Duet firmware update by using the Bossa software on a PC and flashing the firmware to the Duet directly via USB connection. That can get it back in sync with the version on the SBC.
        https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#all-other-duet-boards
          droftarts administrators @darylprice
          @darylprice sending M997 from DWC should be sufficient to update the 6HC to the same firmware version as DSF. I think DSF will only auto update minor versions (ie 3.5.3 to 3.5.4) but not major versions (ie 3.4 to 3.5), but M997 should fix that. See https://docs.duet3d.com/User_manual/Reference/Gcodes#m997-perform-in-application-firmware-update
