DWC Dashboard Tools section does not show correct MAX temp?
Hello All-
After solving some rather simple, but infuriating problems with my new build, I now have a whole new set of problems. Yippee!
***EDIT Never mind...I found it. After seeing another recent post, I realized the DWC did not auto populate the tools max temp range... you have to add this in your self.
That's what I get for assuming that just because you run a PID tune with an updated max temp, the software does not automagically add in this new max temp.
(feature request, perhaps?)
My newly commissioned RatRig V-Core 3 came with some pretty basic hardware, including a Bondtech BMG extruder and E3DV6 hotend, Nothing great there but until I can get my new parts printed for my EVA3.0 Mosquito hotend, I'm stuck with it for the time being. According to E3D, the V6 can handle up to 300c with the stock aluminum block. I want to print my new printer parts in PETG or better, so I re-ran my PID tuning and set the max temp to 285c (well within range). I applied the newly updated PID tuning parameters to my config.g and restarted as suggested.
When I look at the active temp dropdown for my hotend, it still only shows 250c which is borderline low for the materials I want to print (256-265)
How can I get the tools dropdown to show the correct max temp?
Surely someone has run into this before....
As always, thank you for any help!
- Cheers!
