    Two heaters and thermistors for heatbed
    Duet Web Control wishlist
    • Michel
      Michel last edited by
      Hello
      My heat bed has two zones to be able to change between 24V supply and 12V supply.
      This leads to an uneven bed temperature if I connect them in parallel and even if i connect
      them in serial.
      For this reason I have connected the first part to the Bed output and the second part to the second
      extruder heater output.
      Is there a possibility in the firmware settings to use the bed temperature setting for both the Bed Heater
      and the second extruder heater?
      • chrishamm
        chrishamm administrators last edited by
        Meanwhile RRF supports multiple bed heaters. You may wish to look into this - if you need more customizations on DWC, I suggest you open a new topic.
        Duet software engineer
