    [3.6.0-beta.4] Code 7 halt, m122 Dump
    Beta Firmware
    • Notepadundefined
      Notepad
      Hi all, Had my first Code 7 today. Ive attached the M122 for any needed debugging
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.6.0-beta.4 (2025-02-11 09:50:40) running on Duet WiFi 1.02 or later
      Board ID: 0JD2M-9F8TA-GJ4TJ-6JTF4-3SD6L-16VG6
      Used output buffers: 3 of 26 (24 max)
      Static ram: 24016
      Dynamic ram: 68220 of which 0 recycled
      Never used RAM 10264, free system stack 68 words
      Tasks: NETWORK(1,ready,15.6%,181) LASER(5,nWait 6,1.5%,214) HEAT(3,nWait 5,0.1%,307) Move(4,invalid,7.0%,239) MAIN(1,running,75.8%,736) IDLE(0,ready,0.0%,29), total 100.0%
      Owned mutexes:
      Last reset 07:38:49 ago, cause: power up
      Last software reset at 2025-02-25 15:15, reason: User, Gcodes spinning, available RAM 12712, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      === Storage ===
      Free file entries: 9
      SD card longest read time 11.5ms, write time 535.5ms, max retries 0
      Segments created 729, maxWait 1677858ms, bed comp in use: mesh, height map offset 0.000, hiccups added 57/113 (3.51ms), max steps late 1, ebfmin 0.00, ebfmax 0.00
      Pos req/act/dcf: 19909.00/20410/-0.49 6675.00/6893/-0.86 15700.00/15693/-0.79
      No step interrupt scheduled
      Driver 0: standstill, SG min 0
      Driver 1: standstill, SG min 0
      Driver 2: standstill, SG min 0
      Driver 3: standstill, SG min 0
      Driver 4: standstill, SG min 0
      Driver 5:
      Driver 6:
      Driver 7:
      Driver 8:
      Driver 9:
      Driver 10:
      Driver 11:
      === DDARing 0 ===
      Scheduled moves 340521, completed 340481, LaErrors 0, Underruns [0, 0, 0]
      Segments left 6
      Code queue is empty
      Movement locks held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 3
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      === Network ===
      Slowest loop: 537.88ms; fastest: 0.01ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 2 of 8
      === WiFi ===
      Interface state: active
      Firmware version 2.2.1
      Module reset reason: Power up, Vcc 3.36, flash size 2097152, free heap 39160
      MAC address a4:e5:7c:03:da:6c
      IP address 192.168.1.174
      Signal strength -71dBm, channel 6, mode 802.11n, reconnections 0
      Clock register 00002002
      The real bamboo printer manufacturer
        dc42 administrators @Notepad
        @Notepad thanks. For these types of error it's the info in the error message that reported Code 7 that's important, but unfortunately you haven't provided that.
        However, I believe I have identified and fixed the cause of Code 7 errors. We expect to release 3.6.0-rc.1 very soon.
        Notepadundefined 1 Reply Last reply Reply Quote 1
        • Notepadundefined
          Notepad @dc42
          @dc42 Dang, Ill try capture it next time. The code 7 has been incredibly rare for me, this is the first over 12 machines
            @Notepad yes, code 7 halts were very rare. The cause I found (supported by debug evidence from two users) only occurred when a particular combination of events occurred. One of those events was the 32-bit step clock counter rolling over to zero within the duration of a move segment in a particular context. That rollover happens once every approx. 95 minutes on Duet 3.
            • Notepadundefined
              Notepad @dc42
              @dc42 I got sent this from the print farm, unfortunately its not the WebUI full log but this might help 495dade4-3336-4218-88a4-b7efe8743d44-image.png be
                @Notepad thanks, that has the very large 'd' value that is characteristic of the Code 7 error that I fixed in rc1. I presume you were running beta 4 or earlier when that message was generated.
                Notepadundefined 1 Reply Last reply Reply Quote 0
                • Notepadundefined
                  Notepad @dc42
                  @dc42 Yup, this machine is still on beta.4 The rollout of RC1 has been applied to most machines, but ones still ill a production job are still on B4
