    Duet wifi 1.0 latest firmware?
    Firmware installation
    • abrasiveundefined
      abrasive
      I have an old Duet wifi 1.0 running my also old D300VS.
      I’m currently on firmware 1.18.1. What’s the latest version of firmware that board will support? I searched for a compatibility chart or list but didn’t come up with anything.
      Thank you!
      Dave
        You can update all the way to the latest 3.5.4.
        https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.4
        Specifically this bin file. https://github.com/Duet3D/RepRapFirmware/releases/download/3.5.4/Duet2CombinedFirmware.bin
        Since you're so far out of date the easiest way to update would be to use a USB connection to a PC and use the Bossa software to flash the firmware directly. https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#all-other-duet-boards
        You'll then need to prepare an SD card with the latest web control version.
        https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.5.4/DuetWebControl-SD.zip
        You won't be able to use the same config files from that old version. The syntax of many commands has changed since 3.x firmware. Creating a new config file set with the web tool would be recommended.
        https://configtool.reprapfirmware.org/
        abrasiveundefined 1 Reply Last reply Reply Quote 0
        • abrasiveundefined
          abrasive @Phaedrux
          Great! I’ll proceed the way you’ve outlined.
          Thank you for the detailed response. Extremely helpful!
