    3.6.0 RC1 python errors in OM with SubscribeConnection
    Beta Firmware
    • achrnundefined
      achrn
      I have Duet 3 MB6HC with Duet 3 Expansion TOOL1LC running 3.6.0-rc.1, SBC mode.
      I have a plugin which is python which makes a subscribe connection then attempts to download the whole object object model (it then goes on to do other stuff, but it fails at trying to get the object model). This was running fine on 3.5.4.
      Before this point is only global variables, imports (including from dsf.connections import SubscribeConnection, SubscriptionMode), define some functions.
      verbose and vTS are both true to generate the logs comments with timestamps.
      # main
      if __name__ == '__main__':
          # establish the dsf-python connection, with some re-tries just in case
          for attempt in range(5):
              try:
                  if verbose: print(("{:.6f} ".format(time.time()) if vTS else '') + 'try subscribe connection', flush=True)
                  subscribe_connection = SubscribeConnection(SubscriptionMode.PATCH, debug=False)
                  subscribe_connection.connect()
              except:
                  time.sleep(3)
              else:
                  if verbose: print(("{:.6f} ".format(time.time()) if vTS else '') + 'got subscribe connection', flush=True)
                  break
          else:
              # ran to end of our attempts and didn't break out so still not established
              # make one last attempt after a longer pause
              time.sleep(15)
          try:
              # get the complete object model once
              # note we cast it to a string in order to feed it in to json.loads
              om = json.loads(str(subscribe_connection.get_object_model()))
      This apparently makes the connection OK (log messages at lines 10 and 16 above appear OK at 3 and 4 below) but then generates a traceback referring to /usr/lib/python3/dist-packages/dsf/object_model/spindles/spindles.py:
      Mar 16 20:19:19 delta DuetPluginService[838]: [info] Plugin PyDaemon: Launching /opt/dsf/plugins/PyDaemon/dsf/pydaemon.py
      Mar 16 20:19:19 delta DuetPluginService[838]: [info] Plugin PyDaemon: Process has been started (pid 2181)
      Mar 16 20:19:19 delta DuetPluginService[2181]: 1742156359.805182 try subscribe connection
      Mar 16 20:19:19 delta DuetPluginService[2181]: 1742156359.806868 got subscribe connection
      Mar 16 20:19:19 delta DuetPluginService[2181]: Traceback (most recent call last):
      Mar 16 20:19:19 delta DuetPluginService[2181]:   File "/opt/dsf/plugins/PyDaemon/dsf/pydaemon.py", line 174, in <module>
      Mar 16 20:19:19 delta DuetPluginService[2181]:     om = json.loads(str(subscribe_connection.get_object_model()))
      Mar 16 20:19:19 delta DuetPluginService[2181]:                         ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
      Mar 16 20:19:19 delta DuetPluginService[2181]:   File "/usr/lib/python3/dist-packages/dsf/connections/subscribe_connection.py", line 43, in get_object_model
      Mar 16 20:19:19 delta DuetPluginService[2181]:     object_model = self.receive(ObjectModel)
      Mar 16 20:19:19 delta DuetPluginService[2181]:   File "/usr/lib/python3/dist-packages/dsf/connections/base_connection.py", line 78, in receive
      Mar 16 20:19:19 delta DuetPluginService[2181]:     return cls.from_json(json.loads(json_string))
      Mar 16 20:19:19 delta DuetPluginService[2181]:   File "/usr/lib/python3/dist-packages/dsf/object_model/model_object.py", line 87, in from_json
      Mar 16 20:19:19 delta DuetPluginService[2181]:     return cls()._update_from_json(**preserve_builtin(data))
      Mar 16 20:19:19 delta DuetPluginService[2181]:            ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
      Mar 16 20:19:19 delta DuetPluginService[2181]:   File "/usr/lib/python3/dist-packages/dsf/object_model/object_model.py", line 160, in _update_from_json
      Mar 16 20:19:19 delta DuetPluginService[2181]:     super(ObjectModel, self)._update_from_json(**kwargs)
      Mar 16 20:19:19 delta DuetPluginService[2181]:   File "/usr/lib/python3/dist-packages/dsf/object_model/model_object.py", line 76, in _update_from_json
      Mar 16 20:19:19 delta DuetPluginService[2181]:     setattr(self, attr_name, attr.update_from_json(json_value))
      Mar 16 20:19:19 delta DuetPluginService[2181]:   File "/usr/lib/python3/dist-packages/dsf/object_model/model_collection.py", line 55, in update_from_json
      Mar 16 20:19:19 delta DuetPluginService[2181]:     self.append(self._item_constructor().update_from_json(item_to_add))
      Mar 16 20:19:19 delta DuetPluginService[2181]:                 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
      Mar 16 20:19:19 delta DuetPluginService[2181]:   File "/usr/lib/python3/dist-packages/dsf/object_model/model_object.py", line 93, in update_from_json
      Mar 16 20:19:19 delta DuetPluginService[2181]:     return self._update_from_json(**preserve_builtin(data))
      Mar 16 20:19:19 delta DuetPluginService[2181]:   File "/usr/lib/python3/dist-packages/dsf/object_model/model_object.py", line 69, in _update_from_json
      Mar 16 20:19:19 delta DuetPluginService[2181]:     setattr(self, json_key_snake, json_value)
      Mar 16 20:19:19 delta DuetPluginService[2181]:   File "/usr/lib/python3/dist-packages/dsf/object_model/spindles/spindles.py", line 38, in active
      Mar 16 20:19:19 delta DuetPluginService[2181]:     self._active = int(value)
      Mar 16 20:19:19 delta DuetPluginService[2181]: TypeError: int() argument must be a string, a bytes-like object or a real number, not 'NoneType'
      Mar 16 20:19:19 delta DuetPluginService[838]: [info] Plugin PyDaemon: Process has been stopped with exit code 1
      I haven't done much digging, but my immediate thought is that all I've done in the script so far is a subscribe_connection.connect() which has succeeded first time (not needing any retries) and then the om = json.loads(str(subscribe_connection.get_object_model())) failing doesn't seem like I've done enough for it to be a problem in my code... (om at this point is empty - om = {} among the global variable definitions).
      My full plugin python file: pydaemon.py (though that's one in which verbose and vTS are False).
        droftarts administrators @achrn
        @achrn One for @chrishamm to look at. Related: https://forum.duet3d.com/topic/37701/
        • droftartsundefined droftarts referenced this topic
        • chrishammundefined
          chrishamm administrators
          Closing as duplicate.
          Duet software engineer
          • chrishammundefined chrishamm locked this topic
