    3.6.0 RC1 python perform_simple_code not working
    Beta Firmware
    • achrnundefined
      achrn
      I've posted another message about trouble with command connections downloading OM, but I've discovered I've got a problem with even more basic DSF from python, so this one probably comes first!
      I'm trying to use CommandConnection perform_simple_code to set a global variable. This was working on 3.5.4, but isn't on 3.6.0 RC1, though the debug messages look like the system thinks it has worked.
      My python script:
      #!/usr/bin/env python3
      # imports
      import sys
      from dsf.connections import CommandConnection
      # create command connection used for communicating with dsf
      print("connect", flush=True)
      cmd_con = CommandConnection(debug=True)
      cmd_con.connect()
      # update value of global variable
      print ('update variable', flush=True)
      res = cmd_con.perform_simple_code('set global.filWeight = 99', async_exec=True)
      print ('result:', res, flush=True)
      cmd_con.close()
      # pack up
      sys.exit()
      running it:
      root@delta:~# ./foobar.py
      connect
      send: {"mode":"Command","version":12}
      recv: {"success":true}
      update variable
      send: {"command":"SimpleCode","Code":"set global.filWeight = 99","Channel":"SBC","ExecuteAsynchronously":true}
      recv: {"success":true,"result":""}
      result:
      root@delta:~#
      but global.filWeight doesn't change to 99 (it stays at 0, from config.g global filWeight = 0).
      I have nothing untoward showing up in journalctl -f or any log files (that I've found).
      Have I missed something fundamental about DSF python in 3.6?
      droftartsundefined chrishammundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @achrn
        @achrn related to https://forum.duet3d.com/topic/37700/ again one for @chrishamm to have a look at.
        • droftartsundefined droftarts referenced this topic
        • chrishammundefined
          chrishamm administrators @achrn
          @achrn There were some errors in the previous 3.5 dsf-python client which renders parts of it unusable with 3.6. Hence I suggest you upgrade to dsf-python 3.6-rc.1, I expect that will fix your problems.
          Duet software engineer
          achrnundefined 1 Reply Last reply Reply Quote 0
          • achrnundefined
            achrn @chrishamm
            @chrishamm said in 3.6.0 RC1 python perform_simple_code not working:
            Should 3.6.0 be available by apt install?
            I've done apt update and apt upgrade but apt list gives me (inter alia)
            python3-dsf-python/unstable,unstable,now 3.5.0-1 all [installed]
            All the rest of the packages seem to have gone to 3.6.0 RC1:
            duetcontrolserver/unstable,now 3.6.0~rc.1 arm64 [installed,automatic]
            duetpimanagementplugin/unstable,now 3.6.0~rc.1 arm64 [installed]
            duetpluginservice/unstable,now 3.6.0~rc.1 arm64 [installed]
            duetruntime/unstable,now 3.6.0~rc.1 arm64 [installed,automatic]
            duetsd/unstable,now 1.1.0 all [installed,automatic]
            duetsoftwareframework/unstable,now 3.6.0~rc.1 arm64 [installed]
            duettools/unstable,now 3.6.0~rc.1 arm64 [installed,automatic]
            duetwebcontrol/unstable,now 3.6.0~rc.1 all [installed,automatic]
            duetwebserver/unstable,now 3.6.0~rc.1 arm64 [installed,automatic]
            • achrnundefined
              achrn @achrn
              @achrn said in 3.6.0 RC1 python perform_simple_code not working:
              Further to that, https://pkg.duet3d.com/dists/unstable-3.6/armv7/binary-armhf/ seems only to contain 3.5 and the 'Packages' file likewise only lists a v3.5
              Package: python3-dsf-python
              Architecture: all
              Version: 3.5.0-1
              Priority: optional
              However, 3.6 RC1 version is on pypi: https://pypi.org/project/dsf-python/3.6.0rc1/
              I've used sudo pip3 install --break-system-packages dsf-python==3.6.0rc1 after which the test script up thread works and the variables gets set to 99. I'll try the other issue I had also.
              It would be good if 3.6.0RC1 could be added to the package repository - it seems to be the only 3.5 package in https://pkg.duet3d.com/dists/unstable-3.6/armv7/binary-armhf/ (unless there's a good reason why it shouldn't be included).
                @achrn It should be available via the package feeds as well now.
