    Filament detection M591 Causing FW Restart
    Firmware installation
    • BMMalundefined
      BMMal
      I am trying to configure the following M591 D3 P2 C6 to enable filament presence detection. However, every time this command is issued, the firmware resets.
      Related, I was trying to use M581 E3 T1 S0 C0 but it was triggering constantly. I figured that might be due to electrical noise which is why I then tried to configure M591 instead.
      This is using FW 1.20
      Duet Ethernet - Most likely the most recent Edge firmware
      Duet X5
      7" Panel Due V2
      Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
        Endstop connector 6 will not work with M591. You need to use 1-5 or 10-11. There is a missing check in the code that you have used a legal pin, and that is causing the reset. I will add that check in the next release.
        • BMMalundefined
          BMMal
          @dc42:
          For now, I'm only using simple switches for my filament sensors.
          Got three sensors figured out. Eventually, I'd like to have 4 filament sensors. I apologize for my ignorance but how do I connect to 10 and 11? I take it I have to map some spare pins to them somehow? I am using a thermocouple board too btw.
          Do you mind explaining why the 0, and 6-9 endstop connectors cannot be mapped for this purpose?
          Duet X5
          7" Panel Due V2
