Cannot use variables for Z parameter in G1 command
I just noticed that I cannot use local and global variables for the Z parameter in G1 commands. It only happens for the Z parameter. X, Y and E (even with multi extruder) are working just fine. Unfortunately I cannot update the Duet currently because it's heavily used but I could not find any bug fixes in the changelogs.
Steps to reproduce
- Have a Duet MB6HC in SBC mode with version 3.5.1.
- Create .gcode or .g file in jobs with this content:
var test = 1 G1 Z{var.test} - Open the job file list.
Expected behavior
Correct parsing of Gcode file.
Actual behavior
Error message with:
Failed to get file info for test.gcode
Cannot convert Z parameter to Single (value {var.test}) -
@RevoAlex please upgrade to 3.5.4 and test again.
