[3.6.0-rc.1] abort metacommand parameter not optional
When you run
abort
in either a macro or just directly in DWC you get the errorabort Error: expected an expression The documentation defines abort as
Abort command abort <opt-expression> This causes all nested macros and the current print file (if any) to be terminated. The expression (if present) is converted to a string, which is included in the message presented to the user and written to the log file. So the expression should be optional. I have not seen any mention of this being changed in the changelog.
Is this a planned change or a bug?
@Serbitar I assume this is in 3.6.0-rc.1 as in the title of this thread. Are you running in standalone mode or SBC mode?
@Serbitar This is going to be fixed in the next release candidate.
In SBC mode, thanks for looking at it!
