    DWC showing up as blank page after M589 command (Duet WiFi 2)
    Duet Web Control
    • sushrutshendeyundefined
      sushrutshendey
      I'm trying to set up an access point for my Duet WiFi 2 using the M589 command in YAT. As far as everything goes, I've followed the steps according to the Duet forum guide, however, when I get to the final step of inputting the IP address into the browser (tried Chrome, Firefox, and Edge), I get a blank page (no DWC controls). I've since tried different laptops/computers, different Network names/passwords, and also checked the SD card files for the Duet WiFi 2; all seem to fine. I would like the resolve this issue ASAP so if someone knows a solution or can let me know if I need a replacement, that would be greatly appreciated.
        Are you following this?
        https://docs.duet3d.com/User_manual/Reference/Gcodes#m589-configure-access-point-parameters
          droftarts administrators @sushrutshendey
          @sushrutshendey For a more comprehensive guide to set up AP mode, see https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#configuring-duet-in-wifi-access-point-mode
          Giving us some detail, eg firmware version, commands that you have sent to the Duet, config.g, how you have set your PC, etc, etc, will help us to resolve this more quickly.
          Have you been able to connect to the Duet via WiFi normally, and seen DWC? ie make sure you have the SD card set up correctly, and that there is a /www folder with the matching version of DWC in it. See https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#sd-card-structure
          • sushrutshendeyundefined sushrutshendey marked this topic as a question
          • sushrutshendeyundefined sushrutshendey marked this topic as a regular topic
