Unable to set HTTP Port for DWC (M586 R) [SBC mode]
Provisioning a new board, having difficulty changing the DWC HTTP port. Ideally I want to access via port 1000, so x.x.x.x:1000 - GCode Dictionary indicates M586 should be able to configure this with the R field.
M586 P0 T0 S1 R1000
I am issuing the above command, expecting to turn on HTTP on port 1000. Instead it turns it on at default port. So seems to be ignoring the R flag. Is there something else that has to be set first? Some other way to configure this? SBC mode require something different?
Not sure what I'm doing wrong, hoping the community can help me out.
Environment is a Duet 3 Mini 5+ running v3.5.4. This is in SBC mode with a RPi4 running 64 bit DuetPi image from 2024-09-19.
Here's a console log:
M115 FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.5.4 ELECTRONICS: Duet 3 Mini5plus Ethernet FIRMWARE_DATE: 2024-11-24 10:44:24 ok M586 HTTP is disabled HTTPS is disabled CORS disabled FTP is disabled SFTP is disabled Telnet is disabled SSH is enabled on port 22 ok M586 P0 S1 R1000 ok M586 HTTP is enabled on port 80 HTTPS is disabled CORS disabled FTP is disabled SFTP is disabled Telnet is disabled SSH is enabled on port 22 ok
@e_cubed99 I'm sorry, the command you mentioned should work, but there appears to be a bug in the plugin that handles network management. I just fixed it for the next version.
For the moment you need to edit
/opt/dsf/conf/http.json
and change the URL from port 80 to 1000. When done, restart the Pi or the web server (sudo systemctl restart duetwebserver
@chrishamm - Thanks for the quick response! Bummer on the anomaly, but the file edit workaround is great for now. Really appreciate the help.
E^3
