DuetWiFi resets often requiring manual WiFi restart (M552 S1)
  • I've noticed a changed behavior with 1.201RC2. Often, after a reload of the firmware due to either changing config.g or pressing the Emergency stop button, WiFi networking will not automatically restart. I have to connect via USB and issue M552 S1. Once I do that, it comes up fine and continues to work until the next reload.
    Here is M122 output from the USB session from before restarting networking. Also attached is my config.g
    Thanks,
    John
    [[language]]
    Used output buffers: 1 of 32 (1 max)
    RepRapFirmware for Duet WiFi version 1.20.1RC2 running on Duet WiFi 1.0
    Board ID: 08DAM-999TL-MQ4S8-6JKDJ-3SJ6K-16BVW
    Static ram used: 15448
    Dynamic ram used: 98976
    Recycled dynamic ram: 264
    Stack ram used: 3584 current, 4512 maximum
    Never used ram: 11872
    Last reset 00:10:13 ago, cause: software
    Last software reset at 2018-02-11 11:59, reason: User, spinning module GCodes, available RAM 11944 bytes (slot 0)
    Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
    Error status: 0
    Free file entries: 10
    MCU temperature: min 30.8, current 31.7, max 32.0
    Supply voltage: min 12.3, current 12.4, max 12.5, under voltage events: 0, over voltage events: 0
    Cache data hit count 942032155
    Slowest main loop (seconds): 0.058267; fastest: 0.000041
    MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
    Scheduled moves: 0, completed moves: 0
    Bed compensation in use: none
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is ready with "M122" in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    Network state is running
    WiFi module is idle
    WiFi firmware version 1.20+1
    WiFi MAC address a0:20:a6:16:eb:66
    WiFi Vcc 3.38, reset reason Hardware watchdog
    WiFi flash size 4194304, free heap 21552
    HTTP sessions: 0 of 8
    Socket states:  0 0 0 0 0 0 0 0
    Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
    ok
    ok
    ok
    Wifi module is connected to access point Aloha, IP address 192.168.62.118
    [[language]]
    ; Configuration file for Duet WiFi (firmware version 1.20 or newer) - Edited 11 Feb 2018 - osh
    ; generated by RepRapFirmware Configuration Tool on Tue Jan 02 2018 16:25:12 GMT-0600 (CST)
    M111 S0                                            ; Debugging off
    G21                                                ; Work in millimetres
    G90                                                ; Send absolute coordinates...
    M555 P2                                            ; Set firmware compatibility to look like Marlin
    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Configure automatic saving on power loss
    ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
    ; Set delta radius, diagonal rod length, printable radius and homed height
    M665 R87.370 L215.15 B85.0 H222.850 X-0.447 Y-0.460 Z0.00
    ; M665 R105.6 L215.0 B85 H250                      ; default M665 form T3P3 Kossel Mini
    M666 X0.07 Y0.25 Z-0.32                            ; Put your endstop adjustments here, or let auto calibration find them
    M208 Z-0.1 S1                                      ; Set minimum Z
    M574 X2 Y2 Z2 S1                                   ; Set active high endstops
    M558 P1 H8 F120 T2400                             ; Set Z probe type to unmodulated and the dive height + speeds
    ;                                                  ; Tip: A larger trigger height in G31 moves you CLOSER to the bed
    G31 P500 X0 Y-11 Z0.20                             ; Set Z probe trigger value, offset and trigger height
    ; G31 P500 X0 Y-11 Z0.245                          ; Starting Point Feb 4 2018
    M557 R75 S20                                       ; Define mesh grid
    M569 P0 S1                                         ; Drive 0 goes forwards
    M569 P1 S1                                         ; Drive 1 goes forwards
    M569 P2 S1                                         ; Drive 2 goes forwards
    M569 P3 S1                                         ; Drive 3 goes forwards
    M350 X16 Y16 Z16 E16 I0                            ; Configure microstepping without interpolation
    M92 X80 Y80 Z80 E404                               ; Set steps per mm - osh - carried from Titan setup 1/2/2018
    M566 X1200 Y1200 Z1200 E1200                       ; Set maximum instantaneous speed changes (mm/min)
    M203 X18000 Y18000 Z18000 E1200                    ; Set maximum speeds (mm/min)
    M201 X1000 Y1000 Z1000 E1000                       ; Set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1000 E800 I40                    ; Set motor currents (mA) and motor idle factor in per cent
    M305 P0 T100000 B3950 C0 R4700                     ; Set thermistor + ADC parameters for heater 0
    M143 H0 S120                                       ; Set temperature limit for heater 0 to 120C
    M305 P1 T100000 B4388 C0 R4700                     ; Set thermistor + ADC parameters for heater 1
    M143 H1 S280                                       ; Set temperature limit for heater 1 to 280C
    M563 P0 D0 H1                                      ; Define tool 0
    G10 P0 X0 Y0 Z0                                    ; Set tool 0 axis offsets
    G10 P0 R0 S0                                       ; Set initial tool 0 active and standby temperatures to 0C
    M550 PCharlotte3D                                  ; Set machine name
    M552 S1                                            ; Enable network
    M586 P0 S1                                         ; Enable HTTP
    M586 P1 S0                                         ; Disable FTP
    M586 P2 S0                                         ; Disable Telnet
    M106 P0 S0 I0 F500 H-1                             ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1 T45                          ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P2 S1 I0 F500 H1 T45                          ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
    ; Including line below from old config - but commented out for now 1/2/2018
    ; M579 X1.005 Y0.998 ; adjust based on 100mm XY square - 5/28/2017 - osh
    T0                                                 ; Select first tool
    Firmware 1.20.1RC2 was replaced by 1.21RC1. There is a new DuetWiFiServer 1.21RC1 to go with it.
  • @dc42:
    I'll upgrade and see if the behavior changes.
    Thanks,
    John
  • I am seeing the same after updating to 1.21RC1 from 1.18 last night. Sometimes it takes a few retries before it connects.
    [c]
    Connecting…
    serial: M105
    Printer is now online.
    serial: M105
    serial: M105
    M122
    SENDING:M122
    serial: M122
    RepRapFirmware for Duet WiFi version 1.21RC1 running on Duet WiFi 1.0 or 1.01
    Board ID: 08DAM-999TL-MQ4S8-6J1FJ-3SJ6L-16BHW
    Dynamic ram used: 99736
    Recycled dyWiFi:
    namic ram: 3600
    Stack ram used: 3568 current, 4520 maximuWiFi: xmit: 0
    m
    Never used ram: 7768
    Last reset 00:13:04 ago, cause: software
    Last software reset at 2018-02-12 00:16, reason: User, spinning module GCodes, available RAM 7808 bytes (slot 1)
    Software reset code 0xWiFi: recv: 0
    Error WiFi: fw: 0
    [ERROR] Error WiFi: fw: 0
    status: 0
    MCU temperature: min 31.9, current 32.4WiFi: drop: 0
    , max 33.1
    Supply voltage: min 13.8, current 14.0, max 14.1, under voltage events: 0, over voltage events: 0
    Driver 0: standstill, WiFi: chkerr: 0
    DriverWiFi: lenerr: 0
    Slowest main loop (seconds): 0.001301; fasteWiFi: memerr: 0
    st: 0.000042
    MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240,WiFi: rterr: 0
    Bed heaters = 0 -1 -1 -1, chamberHWiFi: proterr: 0
    eaters = -1 -1
    WiFi: opterr: 0
    Segments left: 0
    aux is idle in state(WiFi: err: 0
    s) 0
    daemon is idle in state(WiFi: cachehit: 0
    s) 0
    === Network ===
    WiFi module is idle
    WiFi firmware version 1.21RC1
    WiFi MAC address 5c:cf:7f:2c:2WiFi:
    4:9e
    WiFi Vcc 3.42, reset reason Turned on by main processor
    WiFi flash size 4194304, free heap 20240
    WiFi: xmit: 0
    WiFi: recv: 9
    WiFi: fw: 0
    WiFi: drop: 112
    WiFi: chkerr: 0
    WiFi: lenerr: 0
    WiFi: memerr: 0
    WiFi: rterr: 0
    WiFi: proterr: 112
    WiFi: opterr: 0
    WiFi: err: 0
    WiFi: cachehit: 0
    WiFi:
    WiFi: xmit: 21
    WiFi: recv: 114
    WiFi: fw: 0
    WiFi: drop: 38
    WiFi: chkerr: 0
    WiFi: lenerr: 0
    WiFi: memerr: 0
    WiFi: rterr: 0
    WiFi: proterr: 0
    WiFi: opterr: 0
    WiFi: err: 0
    WiFi: cachehit: 0
    WiFi:
    WiFi: xmit: 4
    WiFi: recv: 0
    WiFi: drop: 0
    WiFi: chkerr: 0
    WiFi: lenerr: 0
    WiFi: memerr: 0
    WiFi: proterr: 0
    WiFi: rx_v1: 0
    WiFi: rx_group: 0
    WiFi: rx_general: 0
    WiFi: rx_report: 0
    WiFi: tx_join: 2
    WiFi: tx_leave: 0
    WiFi: tx_report: 2
    WiFi:
    WiFi: xmit: 0
    WiFi: recv: 0
    WiFi: fw: 0
    M552 s1
    SENDING:M552 s1
    serial: M552 s1
    WiFi: mode : sta(5c:cf:7f:2c:24:9e)
    WiFi: add if0
    WiFi: scandone
    WiFi: ../src/SocketServer.cpp(353): found network SUPERNET
    WiFi: sleep enable,type: 2
    serial: M105
    WiFi: scandone
    WiFi: state: 0 -> 2 (b0)
    WiFi: state: 2 -> 3 (0)
    WiFi: state: 3 -> 0 (4)
    WiFi: reconnect
    serial: M105
    WiFi: scandone
    WiFi: reconnect
    serial: M105
    WiFi: scandone
    WiFi: state: 2 -> 0 (2)
    WiFi: reconnect
    serial: M105
    WiFi: scandone
    WiFi: reconnect
    serial: M105
    WiFi: scandone
    WiFi: state: 3 -> 5 (10)
    WiFi: add 0
    WiFi: aid 8
    WiFi: cnt
    WiFi:
    WiFi: connected with SUPERNET, channel 6
    WiFi: dhcp client start…
    serial: M105
    serial: M105
    serial: M105
    WiFi: pm open,type:2 0
    serial: M105
    serial: M105
    serial: M105
    WiFi: ip:10.25.29.45,mask:255.255.255.0,gw:10.25.29.125
    Wifi module is connected to access point SUPERNET, IP address 10.25.29.45
    [/c]
    thanks Ed
  • @JohnOCFII:
    I upgraded to the new firmware and WiFi firmware.
    I did a successful one hour print, followed by 2 emergency stops and 2 config.g change/reloads. The WiFi restarted automatically as expected.
    Thanks!
    John
  • After seeing your reply I decided to reload the wifi firmware only and that seems to have done the trick. Tried a few restarts and all good. Thanks!
