    New Steppers Settings in Config.g
    Firmware installation
    • Jpmc86undefined
      Jpmc86
      Hey guys! I just received new steppers that I purchased for my duet3d wifi upgraded rostock v3. I was wondering if anyone can help me on setting the right settings within the config.g file. The steppers I bought are 17M19-2004S, the specs are as follows:
      Electrical Specification
      Manufacturer Part Number: 17HM19-2004S
      Motor Type: Bipolar Stepper
      Step Angle: 0.9 deg
      Holding Torque: 46Ncm(65.1oz.in)
      Rated Current/phase: 2.0A
      Voltage: 2.8V
      Phase Resistance: 1.4ohms
      Inductance: 3.0mH ± 20%(1KHz)
      Can anyone lead me in the right direction, I would greatly appreciate it. Thank you!
      Juan
        I suggest you set the XYZ motor currents in M906 to 1200 or 1300mA and leave the microstepping at the default x16 with interpolation enabled.
        • Jpmc86undefined
          Jpmc86
          @dc42:
          Thanks for the input! I have made the adjustments and they are now working nicely. The only thing now is that when I send G32 to do calibration the hot end lowers to about the mid height of what it used to do and starts probing with no success. For reference the steppers I had were the original 1.8deg steppers from Rostock v3. Any ideas?
          • Dougal1957undefined
            Dougal1957
            you need to double the steps/mm in the M92 commands for the axis that you changed the motors on!
