Hypercube Corexy Problems.
  • So i have tried for 2 days and now im about to throwout my printer. so i guess i ask here and see if the proes know what im doing wrong.
    First issue movement.
    My x-axis moves the correct way. My Y axis is reversed.
    my X-axis endstop works homes perfect Y axis just drives past it and crashes. the endstops shows triggered and open when i run M119
    when i home z it starts to lower the bed. buth the movement for the z is correct.
    And my last problem
    my printer does not connect to the wifi.
    i only get the error
    Error: unsupported command M587 s"Gryta" P"*******"
    M586 is not implemented on this printer
    ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
    ; generated by RepRapFirmware Configuration Tool on Sun Feb 25 2018 18:12:12 GMT+0100 (Västeuropa, normaltid)
    M667 S1 ; Select CoreXY mode
    M550 PHypercube ; Set machine name
    M551 Preprap ; Set password
    M552 S1 ; Enable network
    M587 S"Gryta" P"***********" ; Configure access point. You can delete this line once connected
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M569 P0 S0 ; Drive 0 goes backwards
    M569 P4 S1 ; Drive 4 goes forwards
    M350 X16 Y16 Z16 E16:16 I0 ; Configure microstepping without interpolation
    M92 X80 Y80 Z1600 E420:420 ; Set steps per mm
    M566 X900 Y900 Z12 E120:120 ; Set maximum instantaneous speed changes (mm/min)
    M203 X6000 Y6000 Z180 E1200:1200 ; Set maximum speeds (mm/min)
    M201 X500 Y500 Z250 E250:250 ; Set accelerations (mm/s^2)
    M906 X800 Y800 Z1000 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X300 Y300 Z450 S0 ; Set axis maxima
    M574 X1 Y1 S1 ; Set active high endstops
    M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
    M557 X20:280 Y20:280 S20 ; Define mesh grid
    M140 H-1 ; Disable heated bed
    M106 P0 S1 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 D0:1 H1 ; Define tool 0
    M568 P0 S1 ; Enable mixing for tool 0
    M567 P0 E0.5:0.5 ; Set mixing ratios for tool 0
  • Update X and Y now move correct. x and y home´s
    Z-axis still has weird issue and wifi still have the same errors.
    https://youtu.be/5W7rJO1TYuU
    M587 S"Gryta" P"*********" ; Configure access point. You can delete this line once connected
  • Xyz problems are now fixed. and the machine homes correct. and everything movies.
    now i got a new error. start to get use to this.
    I updated to 1.20 and reconfiged the Config.g with the config tool.
    someone told me that i needed to use 'in the password (no babbeldabb is not my real password)
    Buth i just get the error Wifi module started Error: Failed to initialise WIFI module, Code -10
    when i write m552 s0 and then m552 s1 i get the response Turn of the currant wifi mode before selecting this one
    ; generated by RepRapFirmware Configuration Tool on Mon Feb 26 2018 10:55:15 GMT+0100 (Västeuropa, normaltid)
    M550 PHyperCube ; Set machine name
    M587 S"Gryta" P"'b'a'b'b'e'l'd'a'b'b!" ; Configure access point. You can delete this line once connected
    M586 P1 S1 ; Enable FTP
    M586 P2 S1 ; Enable Telnet
    M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
    M203 X6000 Y6000 Z300 E1200:1200 ; Set maximum speeds (mm/min)
    M201 X500 Y500 Z100 E250:250 ; Set accelerations (mm/s^2)
    M906 X800 Y800 Z1200 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M208 X300 Y300 Z400 S0 ; Set axis maxima
    M574 X1 Y1 Z1 S1 ; Set active high endstops
    M558 P0 H5 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
    G31 P600 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
    M557 X15:285 Y15:285 S20 ; Define mesh grid
    M106 P1 S1 I0 F500 H T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P2 S1 I0 F500 H T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
    1. You only need to prefix lower case characters in the M587 ssid or password with single quote if you are sending those commands from a gcode sender program that converts everything to uppercase before sending it. You do not need it if you have the M587 command in a file on the SD card.
    2. Sounds like you have incompatible main firmware and wifi firmware versions installed. Put the SD card in a PC and copy the 1.20 version of DuetWiFiServer.bin into /sys. Then put it on the Duet, start the Duet and send M997 S1 to install it.
  • @dc42:
    Yeah thanks that did work to upgrade it.
    now it´s just i need to remove the "trusted" ssid because my router was to far away. and it temp connect than loose connection. i added a new router beside the printer. buth now i cant find how to remove the old trusted ssid and add a new one.
    Use M588 to remove a ssid from the list, and M587 to add a new one.
