    Add S2 parameter to head movement button G1 actions
    Duet Web Control wishlist
    • robmundefined
      robm
      With the change in 1.21RC3 disallowing G0/G1 moves if the relevant axis is not homed, I propose changing the head movement commands associated with buttons on the 'Machine Control' tab to have the S2 parameter. At least for the moves less than 50mm - buttons so enabled could have some colour or graphical change to indicate that they will move regardless of homing state.
      I find it is common to need to move some part of the printer after powering up and it may not be appropriate / desirable / safe to home an axis first.
      • resamundefined
        resam
        I was wondering the same - but didn't have time to test it yet.
        Does this mean DWC and PanelDue need to be updated so the jogging buttons work again?
        • robmundefined
          robm
          redundant now, can set
          M564 H0 ; allow moving axes without homing first
          if you want this.
          • daveidmxundefined
            daveidmx
            If this feature is implemented, it should take into consideration that G1 S2 moves on delta and corexy command individual motors to move, rather than moving in XYZ-space.
            <edit>I see this has already been implemented, and there has already been a bug fix for this.</edit>
