    New PanelDue firmware 1.21RC4 available
    Firmware installation
    13
    35
    3106
      You can get it from https://github.com/dc42/PanelDueFirmware/releases. It's compatible with RRF 1.20 and 1.21RC versions.
      • mrac1
        mrac1 last edited by
        Thank you for this new Update, but I can't find the whatsnew.md on github?
          I've just added a link to it on the release page.
          • mrac1
            Thank you! 🙂
            • Si3
              Si3 last edited by
              Can this be updated over web control or does it have to be done over usb?
              • resam
                resam last edited by
                DC42: the "github release title" shows an incorrect version number: 1.20RC4 instead of 1.21RC4
                https://github.com/dc42/PanelDueFirmware/releases/tag/v1.21RC4
                @Si3:
                No, current PanelDue version need to be updated via USB.
                edit:
                ehm, the WHATS_NEW mentions "1.20beta4", the commit message "1.20RC4", and the tag is "v1.21RC4"….
                • garyd9
                  garyd9 last edited by
                  Looks good… Some non-bug feedback:
                  1. The dimming function is great, but it'd be nice if it didn't dim when there's a M291 message being displayed. It'd also be nice if it didn't dim while printing. The idea would be to dim if there's nothing going on (when idle.) Perhaps dimming can be controlled with a G-code command? (Then I can turn OFF dimming while printing and turn ON dimming in stop.g or sleep.g.)
                  2. Macros: Love it. It's perfect for those "ATX Power On" type macros. I also like that the full macros page is two column now.
                  I haven't seen any other differences (so far.)
                  Thank you
                  Gary
                  • nyt
                    nyt last edited by
                    Printer has two extruders, disabling E0 breaks the display and can no longer see E1.
                    M563 P0 D-1 H-1
                    Disabling E1 does this:
                    • k3lag
                      k3lag last edited by
                      Installed this evening. So far everything works as expected. I really like the dimming feature. It's exactly what I wanted. In fact, we watched a movie in the home theater tonight and it was nice not seeing the display in the corner of my eye.
                      • mrac1
                        Before I update my PanelDue, is there a way to disable the dimming feature? Cause, I don't need a display that show's me a blank screen.
                          @nyt, thanks for the feedback, I'll look into those issues.
                          @mrac1, It doesn't go blank, it dims.
                          @garyd9, I'll ,change it so that it doesn't dim while there is a message that requires acknowledgement.
                          • nyt
                            nyt last edited by
                            also love the dimming
                            • Dougal1957
                              Dougal1957 last edited by
                              David
                              Have you built the 7.0C Version for the V2 boards?
                              I have downloaded it and flashed the board but it is still showing as 1.20B1.
                              Tried it 3 times just in case!
                              Doug
                                @Dougal1957:
                                David
                                Doug
                                I thought I had, but I've just rebuilt it and re-uploaded it. So please try again.
                                • TickTock
                                  TickTock last edited by
                                  I had difficulties at first - turned out to be simply a bad USB cable - new firmware seems to be working well. May have more feedback after I've used it a bit.
                                  • garyd9
                                    I'd submit a pull request for this, but I'm currently at my paying job so can't fork, edit, etc:
                                    A couple of suggestions.
                                    First, move the code that dims the brightness to a simple function. A decent compiler will inline this, so there shouldn't be any overhead for a function call, but it's cleaner and more consistent with existing code such as RestoreBrightness() being a function.
                                    In PanelDue.hpp, add a declaration for:
                                    [c]extern void DimBrightness(void);[/c]
                                    In PanelDue.cpp (and hpp), add a new function:
                                    Buzzer::SetBacklight(nvData.brightness >> 3); // or just /8.
                                    isDimmed = true;
                                    [/c]
                                    Also in PanelDue,cpp, around line 1321 in main(), call DimBrightness() instead of calling setbacklight() and setting isdimmed
                                    Next, because the loop in main() is basing the dimmer timeout on the lastActionTime variable (and I don't see it being used for any other purpose), it might be a good idea to call "lastActionTime = SystemTick::GetTickCount()" within RestoreBrightness() (so the timers work when RestoreBrightness() is called from UserInterface.cpp, for example,)
                                    Finally, in PanelDue.cpp, in the function SetStatus(), it might be nice to turn the backlight back on if/when the printer status changes. In that function, within the conditional for (newStatus != status), call RestoreBrightness()
                                    (None of this is tested at all. I was just browsing your github during my lunch…)
                                    • DjDemonD
                                      DjDemonD last edited by
                                      @NYT - whats the content of your clear heater faults macro (I am just being lazy)
                                      • sscott1130
                                        sscott1130 last edited by
                                        @DjDemonD:
                                        I personally use M562 P1 is what I use (only one extruder and never had a fault with the bed heater)
                                        • DjDemonD
                                          Thanks.
                                          • Dougal1957
                                            @dc42:
                                            @Dougal1957:
                                            David
                                            Doug
                                            Tried this again and it still shows as 1.20Beta 1 it's as if the Github hasn't refreshed time stamp shows same as the original files as well on the Git.
                                            Doug
                                            Ignore that My bad I was getting them from https://github.com/dc42/PanelDueFirmware/tree/master/Release/Edge-old which tho are labeled as 1.20rc4 they are all different file lengths from the ones in the release folder. Pays to follow links rather than go to the source GitHub
                                              Please confirm that you are getting it from here https://github.com/dc42/PanelDueFirmware/releases/tag/v1.21RC4.
                                              • Dougal1957
                                                @dc42:
                                                See my edited post above all now sorted thanks.
                                                Doug
                                                  I see what happened. I renamed the Edge folder to Edge-old because I didn't want people using it; but the renaming means that github thinks the files init are new, so it has labeled then as being from the beta4 commit.
                                                  • timcurtis67
                                                    timcurtis67 last edited by
                                                    Is it necessary to update to a version 3 board if I want to add a splash screen to my 7" paneldue? I have a V2 currently.
                                                    • Dougal1957
                                                      @dc42:
                                                      Well I am getting old and senile David so get easily confused. but all sorted now
