SSID Why wont it connect in roaming…
I have a fibre router as my main gateway with thye SSID Studio I also have in another room a wireless router ( the signal is weaker from the gateway).
Now it too also has SSID Studio (that way i have roaming in the house which works same SSID and password all is ok. for PClaptops mobile etc.
except the duet. It keeps say the password is wrong which is impossible as for everything else it worksIf i turn off the router in the room it will connect to the main gateway without problems. Remember SSID and password are the same.
Any Ideas could it be something to do with the mac address of the routers?
OK found out that the security type has to be the same one both routers, some device don't care bu the duet does.
