Switch Extrude and Retract Button placement on panel due
  • This is a little thing_
    If you have fat fingers , like me, it is easy to misfire on even the 7 inch panel due. The Extrude button on the Extrude menu in the lower left hand corner is right next to the highest settings for extrusions. I only set these when I am retracting. There have been many times where I am trying to retract and I accidentally hit extrude and BOOM… im trying to extrude 100mm at 100mm/s.
    If it was reversed the extrude button would be on the side with the slower extrusion speeds and vice versa..
    Small issue.
  • Moderator
    I would say this is a larger issue with touch target size and spacing through out the PanelDue UI. I'd like it if all the buttons had a little more empty space padding between them to make it harder to fat finger it. The macro screen is particularly troublesome. I realize it's a balance between having all the buttons visible and legible and also touchable with a finger.
    Try touching the buttons with your fingernail instead of with the pad of your finger.
