    Workplace change in simulation
    Firmware wishlist
    • Catalin_ROundefined
      Catalin_RO
      With firmware 1.21 simulation is properly done using workplace coordinates but at the end of the simulation the currently selected workplace is lost. In my case the config.g file ends with a G54 and after simulating a file I have to manually send it in order to use workplace 1 coordinates again! The offsets are not lost, just a different set is used.
        I have added "At the end of a simulation, restore the original workplace coordinate selection" to the list. Is that what you meant?
          Catalin_RO
          yes! Thank you!
