Homing failed, heating failed. Delta HC-250
  • We bought duet 3d board online from build3dprinter.eu. We received board on 2nd April, 2018 for our printer DELTA HC-250. we updated firmware to 1.21. now, We are facing the following problems. We read all the documentation & many forums regarding to this problem but nothing work.
    1. The Printer homing command fails to execute. We are getting homing fail error.The motor dont move at all.
    2. While heating the heated bed after 30 temp. rise we get error message heating failed the temp. rise is lower than 1.20/sec.
    3. also suggest us how to configure the probe.
      config file
    config file
    ; Configuration file for testing Duet Ethernet and Wifi with V1.19.2 firmware
    FOR TESTING ONLY! USE https://configurator.reprapfirmware.org/ to generate configuration files for your printer!
    ; Communication and general
    M111 S0 ; Debug off
    M550 DELTAHC250 ; Machine name and Netbios name (can be anything you like)
    M551 Preprap ; Machine password (used for FTP)
    ;*** Networking
    M552 S1 ; Turn network on
    ;*** Ethernet networking: Adjust the IP address and gateway in the following 2 lines to suit your network
    M552 P192.168.1.14 ; (0 = DHCP)
    M554 P192.168.1.255 ; Gateway
    M553 P255.255.255.0 ; Netmask
    M555 P2 ; Set output to look like Marlin
    G21 ; Work in millimetres
    ; Disable Fan 1 thermostatic mode
    M106 P1 H-1
    ; Axis and motor configuration
    M569 P4 S1 ; Drive 4 goes forwards
    M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
    ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
    M665 R105.6 L215.0 B85 H250 ; set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
    M350 X16 Y16 Z16 E16:16 I1 ; Set 16x microstepping with interpolation
    M92 X80 Y80 Z80 ; Set axis steps/mm
    M906 X1000 Y1000 Z1000 E800 I60 ; Set motor currents (mA) and increase idle current to 60%
    M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2)
    M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
    M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
    ; Thermistors
    M305 P0 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
    M305 P1 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set first nozzle thermistor ADC correction
    M305 P2 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set 2nd nozzle thermistor ADC correction
    ; Adjustments for Lite6 hotends used as dummy heaters on test rig
    M307 H0 A250 C140 D5.5 B1
    M307 H1 A250 C140 D5.5 B0
    M307 H2 A250 C140 D5.5 B0
    M106 P1 S-1 ; disable thermostatic mode for fan 1
    ; Tool definitions
    M563 P0 D0 H1 ; Define tool 0
    G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
    ;*** If you have a single-nozzle build, comment the next 2 lines
    M563 P1 D1 H2 ; Define tool 1
    G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
    M92 E663:663 ; Set extruder steps per mm
    ; Z probe and compensation definition
    ;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command
    M558 P1 X0 Y0 Z0 ; Z probe is an IR probe and is not used for homing any axes
    G31 X0 Y0 Z4.80 P500 ; Set the zprobe height and threshold (put your own values here)
    ;*** If you are using axis compensation, put the figures in the following command
    M556 S78 X0 Y0 Z0 ; Axis compensation here
    M208 S1 Z-0.2 ; set minimum Z
    T0 ; select first hot end
    M117 Use https://configurator.reprapfirmware.org/
    This is a bl touch style probe but its deployed and retract is manually.
  • M122
    Used output buffers: 3 of 32 (10 max)
    RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
    Board ID: 08DDM-9FAM2-LW4S4-6J1DJ-3SJ6M-TJVZY
    Static ram used: 16152
    Dynamic ram used: 100800
    Recycled dynamic ram: 1832
    Stack ram used: 1224 current, 4400 maximum
    Never used ram: 7888
    Last reset 00:02:04 ago, cause: power up
    Last software reset at 2018-04-04 17:43, reason: User, spinning module GCodes, available RAM 7760 bytes (slot 3)
    Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
    Error status: 0
    Free file entries: 10
    MCU temperature: min 62.5, current 109.4, max 109.5
    Supply voltage: min 0.5, current 12.6, max 12.7, under voltage events: 0, over voltage events: 0
    Date/time: 2018-04-04 20:49:36
    Slowest main loop (seconds): 0.014060; fastest: 0.000041
    MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
    Scheduled moves: 0, completed moves: 0
    Bed compensation in use: none
    Heater 1 is on, I-accum = 0.0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is running
      WiFi firmware version 1.21
      WiFi MAC address 5c:cf:7f:76:5f:f6
      WiFi Vcc 3.28, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 17032
      WiFi IP address 192.168.0.109
      WiFi signal strength -57dBm, reconnections 0, sleep mode modem
      Socket states: 2 0 0 0 0 0 0 0
      === Expansion ===
  • why does it show not available? how to solve this issue
    Your images are showing "3rd party hosting has been temporarily disabled" so I am not able to see them however:
    1. Please test the motors individually as described at https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter#Section_Testing_the_motors_individually. If the motors don't move:
    • Send M906 to check that the motor currents are as you set them (XYZ all 1000mA). if they are all zero then config.g was not read from the SD card at startup.
    • Check that the blue LED on the Duet is illuminated, indicating that you have VIN power to the Duet.
    2. Heater temperature rise not as expected: tune the bed heater using M303. See https://duet3d.dozuki.com/Wiki/Spurious_heater_faults_and_how_to_avoid_them.
    3. See https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe and https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer. What type of Z probe do you have?
  • I hope you can see the images
  • The images were clicked by our phone and computer I don't know why it shows this message
    No, I still can't see the images. This is a common problem with photobucket, I think you need to have a paid-for account for other people to see them.
    PS - if you want to use Dropbox to host your images, replace ?dl=0 at the end of the Dropbox URL by ?raw=1.
  • Is it possible to send you the image through email
    Please host them on imgur or dropbox. See https://www.csoonline.com/article/3205765/internet/photobucket-replaced-millions-of-images-with-ransom-demand.html for more about the photobucket issue.
  • Thanks for the advice will do it.
    Also please post your homedelta.g file here as text, as you did with your config.g file.
    Thanks, I can see those images.
    1. Homing failed: I still need to see the contents of your homedelta.g file.
    2. Heating fault (temperature rising too slowly): see my reply yesterday, https://www.duet3d.com/forum/thread.php?pid=44742#p44742.
  • homing problem is solved the homing file had everything commented
    Thanks
  • The z probe always shows at min stop. The threshold value is shows 1000 and when triggered it shows 165 how to reverse this one ?
    @JGR:
    Add parameter I1 in your M558 command. That's letter-i followed by digit-1. Better still, use the NC conrtacts of your switch instead of the NO contacts, which is safer if the switch becomes disconnected.
  • yes it solved the problem. Is it ok if we use 31865 board for PT 100 sensor with a reference resistance of 430ohms. I have read the instructions where it says use 400ohms Ref resister. we also have a Resister 391 ohms but have to replace that one on the board. we have also order the daughter board but it will take 2-3 week to reach our office. Is it possible to use 31865 board as we currently have in stock.
    To use a PT100 board with a 430 ohm reference resistor, use parameter R430 in the M305 command that configures the heater to use that PT100 channel.
  • this is the new config file
    M111 S0 ; Debug off
    ;*** Networking
    M106 P1 H-1
    ;M574 E0 S1
    M665 R105.6 L215.0 B85 H322 ; set delta radius, diagonal rod length, printable radius and homed height
    ; Thermistors
    M305 P1 X200 ; Put your own H and/or L values here to set first nozzle thermistor ADC correction
    M305 P1 X200 ; Put your own H and/or L values here to set 2nd nozzle thermistor ADC correction
    M305 P2 T100000 B3950 R4700 H30 L0
    ;heated chamber
    M141 H2 ; heater 3 is the chamber heater
    M301 H2 B1 ; use bang-bang control for the chamber heater
    M307 H0 A250 C140 D6.5 B1
    M307 H1 A250 C140 D6.5 B0
    M307 H2 A250 C140 D6.5 B1 S0.5
    M143 H0 S170
    M143 H1 S410
    M143 H2 S95
    ; Tool definitions
    M563 P1 D1 H1 ; Define tool 1
    M558 P4 X0 Y0 Z0 F100 I1 T2000 H15 ; Z probe is an IR probe and is not used for homing any axes
    G31 X0 Y18 Z2.80 P500 ; Set the zprobe height and threshold (put your own values here)
  • All the heaters are fluctuating more or less 5C even after auto tuning. The Chamber behaves a little wired sometime it gives the temperature rise error and some time it doesn't. please guide us through right procedure.
    Also during bed levelling, While clicking at the UI Autobedlevel button it will take all the points correctly , but if we give the g32 command the head will move outside the bed size to take the points.
