is the mesh leveling capable of extrapolation?
hello again, just curious if the bed leveling is capable of extending the mesh by assumption to areas its unable to probe? or if not could it be a feature request?
regards
Gav
Yes it already does that. It takes the average tilt and extrapolates it beyond the probed area.
oh good, what about the unprobed areas (mesh 0mm points)? is it able to assume those points? i mean for mainly for getting a rough figure in there as you have to adjust them anyway
The unprobed areas that show as 0 in the height map (without a decimal point) are regions where extrapolation is used.
ok thank you for the confirmation
cheers
