    Grid bed compensation
    Firmware wishlist
    23
    100
    15303
      You asked for grid bed compensation to be added to RepRapFirmware, and now you can preview it in the latest developer build (1.17dev6). In brief:
      1. Define a grid like this:
      M557 X20:180 Y20:180 S20  ; define a grid covering the XY area indicated with the specified grid spacing
      or:
      M557 R100 S20  ; define a grid with the specified radius and spacing (for delta printers)
      If you provide both X and Y ranges and a radius, then the intersection will be probed.
      2. Send G29 to probe the bed.
      3. If you want to view detailed results, download file /sys/heightmap.csv. The first 3 lines describe the parameters of the grid. After that come the height measurements, 1 row per scan in the X direction from lowest X to highest X. The rows are ordered from lowest Y to highest Y. A value of 0 with no decimal point means that the point was not probed because it fell outside the defined grid radius or was inaccessible due to probe offset.
      Those of you with programming experience may wish to turn the data into a graphical height map. I am hoping that this can be included in DWC eventually, if HTML5 and Javascript are up to it.
      Please note, I haven't implemented G29 S2 (load height map from file) yet. Also, any sort of G32 probing cancels the height map. So on a delta printer you need to run auto calibration first and G29 second.
      • T3P3Tony
        As an example I ran a quick probe on my BigBox bed:
        [[language]]
        RepRapFirmware height map file v1 generated at 0116-10-24 07:54
        xmin,xmax,ymin,ymax,radius,spacing,xnum,ynum
        30.00,210.00,30.00,150.00,-1.00,60.00,4,3
        -0.024,0.090,0.206,0.399
        0.065,0.175,0.250,0.327
        -0.049,0.111,0.249,0.405
        And I thought my bed was flat!
        • DjDemonD
          DjDemonD last edited by
          That works brilliantly. Word of warning if doing this on a delta set a radius carefully to avoid crashing the head into anything near the edges of the bed.
          So does this apply compensation when printing or is it currently just for measuring?
          Pretty flat though (its tooling plate).
          RepRapFirmware height map file v1 generated at 0116-10-23 11:56
          -120.00,120.10,-120.00,120.10,150.00,30.00,9,9
          0,0,0.024,0.030,0.001,-0.091,-0.119,0,0
          0,0.062,0.054,0.033,0.040,-0.029,-0.014,-0.087,0
          0.026,0.047,0.056,0.005,0.048,0.031,0.054,0.014,-0.024
          0.045,0.042,0.030,0.024,0.016,-0.021,-0.024,-0.027,0.034
          -0.001,-0.035,-0.000,-0.029,0.018,0.015,-0.004,0.046,-0.001
          0.019,-0.001,0.068,-0.065,0.011,-0.015,-0.006,-0.010,-0.001
          -0.011,-0.042,0.005,-0.041,-0.020,0.020,0.015,0.023,0.020
          0,-0.022,-0.018,-0.005,-0.021,0.025,-0.024,-0.035,0
          0,0,0.032,0.051,0.052,0.041,0.041,0,0
            Yes it does apply compensation when printing in the dev6 build.
            • Dougal1957
              Dougal1957 last edited by
              David Does it take account of the H Offsets from the Bed.g for a delta? or at least an approximation of them
              • DjDemonD
                It works. Even with an autocalibration deviation of 0.2, I wasn't getting an even 1st layer over the whole bed. Now I am.
                  The autocalibration takes account of the H offsets in bed.g but the grid bed compensation doesn't.
                  • Alex9779
                    Alex9779 last edited by
                    @dc42 isn't it G29 S1 to load a height map? S2 is described to clear the map…
                    • Alex9779
                      Is there a file that is executed before the probing is done and after? Like "bed.g" for the simple bed leveling?
                      I am playing with the BLTouch and I have to deploy it before and undeploy after…
                      • Sniffle
                        Sniffle last edited by
                        DC42 how would you like us to report errors when testing the dev branches? I also posted this on github just copy/pasting it here to cover all bases.
                        Not sure how you would like testers to report potential problems from the testing of the Dev firmware. At least this initial time I will post both here and on duet3d forums to find out where you would prefer reports be placed.
                        Machine: C-bot Variant CoreXY
                        Board: Duetwifi 1.0
                        Additions: 7" Paneldue, IRProbe
                        Firmware Version: 1.17 Dev6
                        Description of problem and steps taken to produce:
                        Following Gcodes entered manually.
                        M557 X30:290 Y70:290 S40
                        G28
                        G29
                        Response from system after G29 finishes:
                        Height map saved to file heightmap.csv - 42 points probed, mean error 0.11, deviation 0.24
                        Checksum error on line 203652
                        Additional notes:
                        I did this 2 other times while adjusting the grid boundaries to make it probe the area of the bed i wanted.
                        the following checksum errors also occured
                        Checksum error on line 202354
                        Checksum Error on line 202718
                        • Sniffle
                          @Alex9779:
                          I could be wrong, but in the web interface, clicking the "Auto Bed Compensation" button enacts the bed.g file, so you should be able to G28, deploy probe, G29, retract probe, move to wherever you want inside of that file and that should cover you.
                          • Alex9779
                            Yeah well I can write macros, actually I have them, and use them…
                            • DjDemonD
                              Yeah I put the G29 into my bed.g after delta autocalibration.
                              • Alex9779
                                Oh that's a nice trick, didn't think about that, I can remove all the G30 from bed.g and just replace it with G29 and keep the deploy and undeploy sequence…
                                  Sniffle, thanks for your report. Reporting bugs here is best. Were you entering the commands on PanelDue, the web interface, or via a USB host when you got those checksum errors?
                                  Alex, I had forgotten that there are probes that need to be deployed. I could make it call deployprobe.g and retractprobe.g at the start and end of G29 S0. But I am now wondering if there is any point, since the bed compensation runs G32 and you can do the deploy and retract in there.
                                  • Dougal1957
                                    David
                                    Is that to say that running a G29 will run the Auto Cal on a delta First before doing the grib Comp.?
                                    I was just going to add G29 at the end of my Start Script in s3d but if I can just replace the G32 with G29 it will be easier
                                    Doug
                                    • DjDemonD
                                      When I tested it yesterday running G29 just does the grid levelling.
                                      If you put G29 into your bed.g after autocal then it will do both when you run the file from start gcode with G32.
                                      • Alex9779
                                        David: it depends on how you rate the new feature.
                                        IMHO G29 is an improved version of G32. Though G32 is not a real feature, at least in RRF. G32 just executes the bed.g script which is just a execution of multiple G30 commands. So G30 with the plane calculation is the real feature.
                                        So what if we declare G32 is bed compensation and G30 and G29 are just two different methods to compensate.
                                        That way we can use bed.g and it depends on what's in it which compensation is done.
                                        On the other hand if you see G29 a replacement of G32 or an alternative then you should allow probe management for G29 too with special macros.
                                        I vote for what I wrote first… I admit I had problems understanding it myself at first, that's why I wrote all the posts above. But now I thought about it and I think using G32 as a general bed compensation command is WTG...
                                        • T3P3Tony
                                          +1 for Alex's approach. Keeping bed.g as theeditable single point for defining what happens makes the most sense.
                                          • Alex9779
                                            For this nothing has to be changed, it is just a definition. But the documentation should probably be updated to emphasize this…
                                            • Sniffle
                                              David, those errors were reported on the PanelDue, they did not occur or at least not reported on the web interface.
                                              As to the above discussion of using bed.g as the single point of reference for enacting whichever compensation you want i definitely agree, but whats the difference between the spiral 5 point compensation and G29… I was expecting G29 to be an automated version of the later.
                                              Is G30/3G32 Planar and G29 mesh? I'm sure its just a matter of terminology crossing my understanding wires.
                                                @Sniffle:
                                                What I meant was: did you enter the M557 and G29 commands on the PanelDue keyboard, or by some other means?
                                                @Sniffle:
                                                The 5 point compensation requires you to set up a bed.g file (or set up the points using M557). It works on Cartesian and CoreXY printers only. You have the option of including trigger height corrections for each probe point, although it's unlikely that you would need to do that on a Cartesian or CoreXY printer.
                                                The new grid compensation can probe a much larger number of points (currently 121 on the wired duet and 441 on the Duet WiFi). You define the area to be probed and it works out the probe points. It can be used on delta printers too. You can't enter trigger height corrections.
                                                • Alex9779
                                                  I found a little issue with the Z offset and dive height. It seems both are connected somehow when probing.
                                                  IMHO this is not ideal.
                                                  Let me describe it a bit…
                                                  Lets assume we have a probe which triggers when the nozzle is 2 above the bed. So with a Z offset of 0 and a dive height of 3 when probing the bed moves to Z=3 and the probes and so on.
                                                  If you already adjusted your offset to 2 so that the nozzle touches the bed then the bed just dives by 1. I think that's because the dive is calculated from Z0 which I changed by setting the offset.
                                                  So if I have to change my offset every now and then I also have to adjust the dive height and add the offset to the desired dive height.
                                                  I stumbled over this issue again because of playing with the BLTouch.
                                                  The problem here is that if the nozzle touches the bed the BLTouch is not able to trigger because it is already triggered. So if I start with a Z offset of 0 and a dive height of 2.5 then all is fine, probing is fast because the bed is just about 1 away from the trigger pin.
                                                  But when I now adjust the offset so that my nozzle touches the bed and the BLTouch lowers the pin it already hits the plate and is triggered resulting in alarm state which will break the probing sequence.
                                                  IMHO the offset should not influence the dive height, the dive height should always be calculated from the trigger point of the probe and not from the Z0 location.
                                                  • Alex9779
                                                    @dc42:
                                                    I wonder how long a probing sequence will last if you max that…
                                                    I won't try until I am not able to load the result back in 😄
                                                    • T3P3Tony
                                                      David, being able to probe 441 points is one thing, I have not dug into your grid compensation code but does having that number of (different) points in the grid have an effect on the gcode->step generation speed? Does that limit the step rate or once the curve is fitted then the process required is the same?
