    M307 hangs for over 2 minutes in RRF 1.21 on RADDS
    Other control boards
    • spinor
      spinor last edited by
      If I enter M307 (using the Octoprint terminal) to either interrogate or change the heater model, RRF responds with the appropriate output but then becomes unresponsive for approximately 2 minutes 10 seconds before returning to normal. I'm fairly sure this didn't happen in any of the previous releases of RRF. Does this happen in the Duet build as well, or just RADDS?
      Here's the output of Octoprint's terminal (including routine temperature polling):
      Recv: ok T:159.6 /0.0 B:24.7 /0.0
      Send: M105
      Recv: ok T:155.6 /0.0 B:24.7 /0.0
      Send: M307 H1
      Recv: Heater 1 model: gain 374.7, time constant 134.0, dead time 6.2, max PWM 1.00, calibration voltage 0.0, mode PID, inverted no, frequency default
      Recv: Computed PID parameters for setpoint change: P10.4, I0.360, D44.7
      Send: M105
      Recv: Computed PID parameters for load change: P10.ok T:151.7 /0.0 B:24.7 /0.0
      [RRF hangs for 2 min 10 sec at this point]
      Send: M105
      Recv: ok T:85.7 /0.0 B:24.4 /0.0
        Does it also hang for 2mins if you send the same commands from Pronterface? If not, that would suggest that it is Octoprint that is hanging.
        • spinor
          Thanks, you're right - it seems OK in Pronterface, so I can use that for hand-tuning the heater. Strange that only M307 seems to be affected, perhaps something to do with Octoprint's temperature polling.
