M591 output or documentation wrong
  • Moderator
    Firmware Name:	RepRapFirmware for Duet 2 WiFi/Ethernet
    Firmware Electronics:	Duet WiFi 1.02 or later
    Firmware Version:	2.0(RTOS)RC2b (2018-05-13b3)
    WiFi Server Version:	1.21
    Web Interface Version:	1.21.1-RC4
    I am setting up a simple filament run-out sensor with a microswitch in Normally Open (so that a loose connector also triggers filament run-out).
    GCode documentation states that I should use P2 in this case "2=simple sensor (high signal when filament present)". When I use M591 D0 P2 C3 and then run M591 D0 it outputs
    Simple filament sensor on endstop 3, output high when no filament
    when I use P1 it says output low when no filament which is exactly the opposite of what the documentation states.
    Which one is right here?
    P.S.: reading the wiki page regarding filament sensors I start doubting if I have to use M591 here at all for this to work (do I?) but either way there is a problem in output.
    P.P.S.: I just realized I do not have to use M591 to get the trigger setup with M581 to trigger. Does M591 have any use for this setup? I wonder because there are P values that imply some kind of use.
    The documentation was wrong. I have corrected it. Thanks for pointing this out.
  • Moderator
    @dc42 Thanks!
    Could you also have a comment on what use M591 has when using a simple microswitch? Documentation says "The action on detecting a filament error is firmware-dependent, but would typically be to run a macro and/or to pause the print and display a message.". So what does RRF do and when does it do that? (At least on my tests it did nothing while not printing something)
    @wilriker said in M591 output or documentation wrong:
    @dc42 Thanks!
    Filament monitoring in RRF is only active when printing from SD card. The action on a filament error is to pause the print and advise you that there has been a filament error.
  • Moderator
    @dc42 said in M591 output or documentation wrong:
    So, basically this is what M581 T1 ... C1 would also do, right?
    EDIT: I also took the liberty to update https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M591_Configure_filament_sensing with your description and replace that generic sentence (that probably has been copied over from http://reprap.org/wiki/G-code#M591:_Configure_filament_sensing) I cited above so in future this will be clear from the start. 🙂
    Yes, except you will get a message telling you why the print was paused.
  • Moderator
    @dc42 Yeah, you are right. I missed that part because when I tested this yesterday I used T9 and my trigger9.g was just having a single M117 in it so I could see what it does. 😉
    Thanks for clarifying this! 👍
  • Moderator
    @dc42 I think I am confused on terminology here. I finished my sensor setup yesterday. As mentioned in the beginning it is a normally-open sensor, so missing filament and bad cable/connector has the same effect.
    Now, everything is hooked up to E0 endstop, filament is present. I can see the LED for E0 enstop is on (because the switch is now closed). Next I ran M591 D0 P1 C3 which corresponds to output low when no filament or high signal when filament present respectively (depending on output of firmware or documentation - which now is in sync).
    When trying to start a print like this, though, it will immediately pause the print and tell me that filament ran out.
    When I change my config to M581 D0 P2 C3 it works as expected.
    I assumed that a high signal corresponds to a lit LED, doesn't it? I am confused.
    A low signal lights the LED.
  • Moderator
    @dc42 OK, thanks.
    I would have never assumed it to be that way but I can accept it. 😂
