    multi wifi network
    Firmware installation
    663
    • BenDiesel
      BenDiesel last edited by
      so I have a machine I take to school and home. I was wondering how to set it up to connect to different wifi automatically. do I have separate m558 in the config.g?
        You can use the M587 command to set up parameters for multiple WiFi networks. See the description of M587 in the GCodes wiki page.
        • BenDiesel
          so dose it store the networks in a separate area? or dose it stay in the config.g? is there a way to set priority for the networks? say I have 2 networks in one area and I prefer to connect to one over the other if/when its available ?
          thanks
            Network details are stored on the wifi module. You should not put M587 network configuration data in config.g, because it exposes your wifi password to anyone who succeeds in accessing the Duet.
            • BenDiesel
              so is there a way to set a priority list?
                No, it connects to the strongest known network that it finds.
                • BenDiesel
                  Ok so if I send the m587 over yat followed by m500 that should save everything ? Or do I need to m500?
                    dc42 administrators @BenDiesel last edited by
                    @bendiesel said in multi wifi network:
                    No, just the M587 command
