    Firmware 2.0RC6 and 1.21.1RC6 released
    Firmware installation
    15
    49
    7.7k
    • cgcaferundefined
      cgcafer
      Hi All,
      There was a problem when i use RC6 without any problem. When it printing i changed M566 value from paneldue then error message appeared and printing stopped.
      Old value was M566 X800 Y800
      New value was M566 X1200 Y1200
      and M122 result,
      12:17:52
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS)RC6 running on Duet WiFi 1.02 or later + DueX2
      Board ID: 08DDM-9FAM2-LW4S8-6JTDG-3SJ6P-1MXBY
      Used output buffers: 1 of 20 (13 max)
      Static ram: 28380
      Dynamic ram: 96516 of which 0 recycled
      Exception stack ram used: 420
      Never used ram: 5756
      Task NETWORK ready, free stack 324
      Task HEAT blocked, free stack 1256
      Task MAIN running, free stack 3560
      Last reset 00:39:03 ago, cause: software
      Last software reset time unknown, reason: User, spinning module GCodes, available RAM 5816 bytes (slot 3)
      Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 8
      Free file entries: 10
      SD card longest block write time: 32.2ms
      MCU temperature: min 23.5, current 25.6, max 26.3
      Supply voltage: min 0.9, current 24.0, max 24.2, under voltage events: 1, over voltage events: 0
      Driver 0: standstill, SG min/max 365/683
      Driver 1: standstill, SG min/max 0/1023
      Driver 2: standstill, SG min/max 0/616
      Driver 3: standstill, SG min/max 0/1023
      Driver 5: standstill, SG min/max not available
      Driver 6: standstill, SG min/max not available
      Expansion motor(s) stall indication: no
      Date/time: 2018-06-05 12:17:51
      Slowest loop: 53.39ms; fastest: 0.06ms
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 121, MaxWait: 141786ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 29
      Bed compensation in use: mesh
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.1
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 38.73ms; fastest: 0.01ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        WiFi firmware version 1.21
        WiFi MAC address 5c:cf:7f:a4:04:fe
        WiFi Vcc 3.36, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 15528
        WiFi IP address 10.0.0.25
        WiFi signal strength -58dBm, reconnections 0, sleep mode modem
        === Expansion ===
        DueX I2C errors 0
        dc42 administrators @daveidmx
        @daveidmx said in Firmware 2.0RC6 and 1.21.1RC6 released:
        @dc42 There were ~70. Half of those are test macros and related subroutines that maybe shouldn't be in there. (The entry-point macros are in /macros but I didn't want the subroutines to show up on the "macros" DWC UI menu.) The other half are config.g, but factored apart such that reusable parameters were in one place.
        https://github.com/daveidmx/VORON/tree/feature/config/Firmware/DuetWifi/V2/daveidmx
        For example, here are my homex.g and homeall.g, written such that the actual Z-hop moves and X/Y/Z probe moves are in their own files. They are re-usable and only need to be changed in one place.
        ; homex.g
        M98 P"homing_zhop_up.g"
        M98 P"homing_probe_x.g"
        M98 P"homing_zhop_down.g"
        ; homeall.g is a slightly optimized XYZ homing script that probes X, Y, and Z together without an intervening Z-hop between each axis
        M98 P"homing_probe_y.g"
        M98 P"homing_probe_z.g"
        M98 P"moveto_center_xyz.g"
        Maybe these should be shipped off to /macros?
        Thanks. I'm hoping to get a fix for the file limit soon, but if not then I'll suggest to Chrishamm that he adds support for subfolders of /sys in DWC, that way you won't have them showing up in subfolders of /macros.
          dc42 administrators @cgcafer
          @cgcafer said in Firmware 2.0RC6 and 1.21.1RC6 released:
          Error status: 8
          Thanks for your report. I suspect that it was random that the problem occurred when you sent the M566 command, however if you find that you can reproduce this fault then please let me know.
          What's happened is that accesses to the SD card failed. In older firmware versions, this usually caused the print to stop where it is with the heaters left on. We have one OEM customer who is a very heavy user and has seen this happen occasionally, going back to firmware 1.21 and earlier. In 2.0RC6 the handling of SD card errors has been rewritten so that the print is terminated properly, error messages are sent and the heaters are turned off.
          At this state I am not sure what causes these errors. Perhaps it is just a temporary hardware glitch or an ESD discharge between a stepper motor body and ground. I am considering adding a mechanism to re-initialise the SD card interface and retry the transaction when a SD card read or write error occurs, as long as the card detect switch indicates that the card hasn't been removed.
          Were you able to access the SD card via DWC or PanelDue after the error occurred, without either resetting the Duet or sending M21?
          The error status 8 indicates that output stack overflow occurred at some point. This is not uncommon, especially when using multiple DWC clients.
          cgcaferundefined 1 Reply Last reply Reply Quote 0
            dc42 administrators @BMMal
            @bmmal said in Firmware 2.0RC6 and 1.21.1RC6 released:
            Error status: 24
            Free file entries: 9
            SD card longest block write time: 762.6ms
            Slowest loop: 821.33ms; fastest: 0.08ms
            Thanks for your report. I think there was an SD card read error, but for some reason it didn't cause the print to terminate. The Error status 24 indicates that you had output stack overflow (which is not uncommon) and that an SD card transaction took much longer than expected. The SD card longest block write time is also much higher than expected. The Slowest loop time is probably related to that.
            • wackyfrogundefined
              wackyfrog
              PanelDue v3.0a 5" FW 1.20(b15) can't connect after update DuetWifi to FW 2.0(RTOS)RC6 (2018-05-29b4), works well until now. PanelDue displays "Connecting...", tried to reset setting. Connected via 4 pin cable.
                dc42 administrators @wackyfrog
                @adegtiar said in Firmware 2.0RC6 and 1.21.1RC6 released:
                If you are powering the Duet with 5V power only, that's normal for now. There will be a new PanelDue firmware release in the next few days that supports the new Standby status returned by RRF 2.0.
                wackyfrogundefined 1 Reply Last reply Reply Quote 0
                  wackyfrog @dc42
                  Yes, using only with 5v.
                  One more thing: when jogging not homed axis I see errors in g-code console:
                  M120
                  G91
                  G1 X-0.1 F3600
                  M121
                  Error: G0/G1: insufficient axes homed
                  Error: Pop(): stack underflow!
                    wackyfrog
                    This post is deleted!
                    • cgcaferundefined
                      cgcafer @dc42
                      @dc42 said in Firmware 2.0RC6 and 1.21.1RC6 released:
                      I sent M122 from DWC after that shutdown all system so i didn't test it.
