    Just had a mid-print reset on 2.01b2
    Firmware installation
    • gtj0
      gtj0 last edited by
      I was standing there watching the printer. None of the axes were even close to their endstops and I wasn't touching the printer.
      Last reset 00:08:56 ago, cause: reset button or watchdog
      doesn't say which it was though so it's not all that helpful. Can we get that message enhanced to say which button or which watchdog it was?
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01beta2(RTOS) running on Duet Ethernet 1.02 or later + DueX5
      Board ID: 08DGM-95BNL-MGPSJ-6JTD8-3SS6K-11XHZ
      Used output buffers: 3 of 20 (7 max)
      Static ram: 28484
      Dynamic ram: 95724 of which 0 recycled
      Exception stack ram used: 308
      Never used ram: 6556
      Tasks: NETWORK(ready,400) HEAT(blocked,1248) MAIN(running,3648)
      Owned mutexes:
      Last software reset at 2018-07-20 19:27, reason: User, spinning module GCodes, available RAM 6408 bytes (slot 1)
      Error status: 0
      Free file entries: 10
      I also had an issue earlier today where the thermostatically controlled heatsink fan just stopped but the print continued. A few minutes later the filament jammed in the hotend and I had to take everything apart to clear it.
        Thanks for your report. On the Duet rev 1.04 we should be able to tell the difference between a watchdog reset and the reset button, but on the older Duets we can't. Unless something is fouling the reset button on your Duet, it's probably a watchdog reset. What's odd is that there is a second watchdog that normally goes off before that one, and it hasn't in this case.
