    LinearDeltaKinematics.cpp
    Firmware developers
    • GizmotronX5000
      GizmotronX5000 last edited by
      I'm attempting to modify the InverseTransform and Transform functions to fit a new kinematics class, but I'm having a bit of trouble following the calculations done in the InverseTransform function. Is there any reference material you have that explains these calculations specifically the way they are done here? I have worked through delta inverse kinematics before, but this seems like a different method than I have used. None of the papers I have found match up exactly either. Thanks!
        I worked out the maths of the Inverse Transform function by solving the simultaneous equations, having at the time failed to find a solution on the Internet. That was before I found that the magic search term was "trilateration". There are lots of ways of doing it, and I expect man of them are more resistant to rounding error than the method I devised.
