    Firmware won't install
    Firmware installation
    • sjason1377undefined
      sjason1377 Banned
      using 1.19.2 on Ethernet. No file name duetethernet.bin found. It won't install over usb and error message not proper firmware for this electronic error placing it directly to sd card. M997 S0 command error not proper for this electronic. It is 2 gen board brand name duet Ethernet. Where is the correct latest stable version for my board? How do I install?
      Seem like non of the usual procedures ever work with this board. Why?
        1. Try uploading the latest version of iap4e.bin, and then installing the firmware.
        2. Check the size of the firmware file you have downloaded. It should be roughly 300kb. If it is much smaller, then you have downloaded the file incorrectly.
