Bltouch help
  • I can not run my bltouch. It's been two weeks now that I have this duet card and I can not print because the bltouch can not finish the autoclibration. I can not understand why and I do not know what to do.
    Can someone help me?
  • https://www.antclabs.com/bltouch
    I have the classic version of 2017. It seems that duet 2.01 does not work in M558 P9 with this version.
    The information about the 32bit card seems to be a bit outdated.
  • This is my problem with the bltouch?
    The duet card must receive 3.3V? So I have to solder a resistance of 240 between the GND and the Z-probe to finally run the auto-calibration?
    https://www.indiegogo.com/projects/bltouch-auto-bed-leveling-sensor-for-3d-printers#/
  • @rafb yes that is likely the case.
    @rafb said in Bltouch help:
    I tested 2.01 and M558 P9 with BLTouch. I have the version with a trace to cut for 3.3V output.
    Please explain what happens when you try to run auto calibration.
  • I added the resistance of 240 ohm. Until the date is not dead!
    If you need more information do not hesitate I will give them to you.
    https://www.youtube.com/watch?v=Nqy6KBnejDo
    Message
    22:31:02Error: Z probe already triggered before probing move started
    22:31:01Error: Z probe already triggered at start of probing move
    Warning: Skipping grid point (-45.0, -135.0) because Z probe cannot reach it
    Warning: Skipping grid point (0.0, -135.0) because Z probe cannot reach it
    Warning: Skipping grid point (45.0, -135.0) because Z probe cannot reach it
    22:31:00Error: Z probe already triggered at start of probing move
    22:30:59G32
  • Config.g
    ; generated by RepRapFirmware Configuration Tool on Thu Aug 02 2018 09:35:23 GMT+0200 (CEST)
    ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
    M665 R155 L397.19 B155 H517 ; Set delta radius, diagonal rod length, printable radius and homed height
    M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
    M92 X80 Y80 Z80 E417.22 ; Set steps per mm
    M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
    M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
    M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1000 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 Z0 S1 ; Set minimum Z
    M574 X2 Y2 Z2 S1 ; Set active high endstops
    M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
    M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
    G31 P25 X0 Y20 Z1.04 ; 1.927 Set Z probe trigger value, offset and trigger height
    M557 R150 S45 ; Define mesh grid
    M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P2 S1 I0 F500 H0 T50 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 D0 H1 ; Define tool 0
    ; Automatic power saving
    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
    ; Custom settings
    ;M591 DO C3 P2 E6.0
    M501
    homedelta.g
    ; homedelta.g
    G91 ; relative positioning
    G1 S1 X705 Y705 Z705 F3600 ; move all towers to the high end stopping at the endstops (first pass)
    G1 X-5 Y-5 Z-5 F3600 S2 ; go down a few mm
    G1 S1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
    G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
    G90 ; absolute positioning
    G1 X0 Y0 F6000 ; move X+Y to the centre
    Bed.g
    ; bed.g
    ; called to perform automatic delta calibration via G32
    G28 ; home all towers
    M190 S60
    ;M98 Pdeployprobe.g; déployer sonde mécanique de Z
    ; Probe the bed at 6 peripheral and 6 halfway points, and perform 6-factor auto compensation
    ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
    G30 P0 X0 Y132.28 H0 Z-99999
    G30 P1 X121 Y69.86 H0 Z-99999
    G30 P2 X129.9 Y-75 H0 Z-99999
    G30 P3 X0 Y-150 H0 Z-99999
    G30 P4 X-125.9 Y-75 H0 Z-99999
    G30 P5 X-121 Y69.86 H0 Z-99999
    G30 P6 X0 Y59.15 H0 Z-99999
    G30 P7 X56.09 Y32.38 H0 Z-99999
    G30 P8 X64.95 Y-37.5 H0 Z-99999
    G30 P9 X0 Y-75 H0 Z-99999
    G30 P10 X-64.95 Y-37.5 H0 Z-99999
    G30 P11 X-56.09 Y32.38 H0 Z-99999
    G30 P12 X0 Y0 H0 Z-99999 S6
    ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
    ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
    ;M98 Pretractprobe.g; rétracter la sonde mécanique Z
    G29
    So the problem is that sometimes the bltouch is reported already triggered at the start of the probing move. Possible reasons for this include:
    • Bad connection between the white wire and the Duet
    • The pin is a little sticky and sometimes the probe deploys too slowly. Try adding a short delay before probing by using the R parameter in the M558 command.
    • The dive height is too low so the probe really is triggered at the start of probing. Try increasing the dive height by 2mm.
  • Hello,
    Once again, thank you for your assistance.
    So I applied all your advice but kidney did not debug this problem of Bltouch Classic. I finally order the BLtouch Smart V2 which I hope will allow me to finally print.
    A +
  • Moderator
    @rafb for what it's worth problems with early versions of the BLTouch classic are very common. The newer version is much improved. Please let us know if it works out for you.
  • Hello,
    back from vacation, I just set up the new bltouch. It works perfectly!
    I still have a problem, why and how to optimize the flatness of my bed?0_1535901506033_Capture d’écran 2018-09-02 à 17.18.00.png
  • Moderator
    What is your printing surface and bed construction?
  • it's glass
  • Moderator
    That height map would indicate a possible mechanical problem. Perhaps something is misaligned or bent.
    How fast are you probing?
  • No, I do not think I have a mechanical problem.
    Look at this bug when I run "auto delta calibration" I have this result.
    But when I do "run mesh grid compensation", j'ai ce résultat.
    This error message G29
    D'ou vient le problème?
  • Moderator
    What are you using for your deployprobe.g and retractprobe.g macros?
  • ; deployprobe.g
    ; called to deploy a physical Z probe
    ;M280 P3 S160 I1
    M280 P3 S10 I1
    ; retractprobe.g
    ; called to retract a physical Z probe
    M280 P3 S90 I1
  • Moderator
    @rafb and how are you deploying and retracting in your bed.g? Are you manually calling it in your homing files or letting g30 handle it?
  • Are you manually calling it in your homing files or letting g30 handle it?
    I do not know and do not understand
    ; bed.g
    M190 S60
    G30 P4 X-129.9 Y-75 H0 Z-99999
    G29
    ; homedelta.g
  • I do not find why I have this problem. I will start from scratch.
    this bltouch seems not to be the best sensor for Duet
  • Moderator
    How do you have it wired?
    Does it light up at all?
    Can you send the servo commands to deploy and retract it?
  • the bltouch works great.
    ; deployprobe.g
    ; appelé à déployer une sonde de Z physique
    ; généré par l' outil de configuration RepRapFirmware le 02 août 2018 09:35:23 Jeu GMT + 0200 (CEST)
    ; M280 P3 S160 I1
    M280 P3 S10 I1
    ; retractprobe.g
    ; appelé à se rétracter d' une sonde de Z physique
    M280 P3 S90 I1
