    Z-Axis not work
    Order discussion
    • Ari Pulkkinen
      Ari Pulkkinen last edited by
      I have problem whit Z-axsis stepper motors.
      I purcase my duetWifi board 20/03/2018 and everything is working great, until yesterday my printer start sound weird when i try go z-home. I noticed that only motion i get z-axis is wierd flutter.
      I check wiring and eaven change diffrent steper motors but not get any real motion in z-axsis, xy-motion works normaly.
      Do you have ideas what can cause this?
      --Ari
        It sounds like only one phase of the Z motors is getting energised. Possible causes include:
        • Bad crimp connection in the motor cable (most likely)
        • Failed stepper driver chip
        • Failed motor (least likely)
        If your E2 motor output is free, one way to diagnose this is to add this line to config.g before any M906 or M350 commands:
        M584 X0 Y1 Z2:4 E3
        Then you can connect one Z motor to the Z connector (with 2 jumpers fitted to the other Z motor connector) and the other motor connected to the E1 connector. This will help you diagnose whether the cable or the driver is faulty.
        • Ari Pulkkinen
          Okay, problem is solved it was motor cable and actually both cable.
          I dont understood why both cable can die same day, anyway this is very cheap repair thank you.
          --Ari
