Lost contact with Duet Wifi
During the commissioning of my printer I was having trouble with induction spikes in the PT100 temp sensor. Resolved that and rewired. However I have now lost all contact with the printer. It doesn't show up in device manager and cannot connect through Repetier or SAM-BA. The 5v led and usb led light on the board and the blue power led if I power it up with mains also fans work. I did push the erase and reset buttons.
I had errors when I had tried to install firmware ie "failed to rename file" or something to that effect and 'failed to save changes" in config.G. SD card seems to be OK.
Does the green 3.3V LED next the blue and red ones light up too? If it doesn't, check your endstop wiring.
Many thanks Dc42 that was the problem. Firmware is sorted out now. Awesome support thanks.
