    Laser Mode Postprocessor for Fusion360
    Laser Cutters
    • MiRundefined
      MiR
      Did somebody already create a Laser capable Postprocessor for Fusion360?
      Hacking the GRBL postprocessor to be Duet compatible is pretty straightforward, but I do not want to duplicate work that was already done, I found one discussion via search that was about the CNC Postprocessor but It does not look like something already got implemented (and CNC and Laser mode are two (slightly) different things anyway.
        If there is already a post-processor for grbl and/or Smoothieware, then I think that should work with the 2.02beta1 version of RepRapFirmware if you use an appropriate M452 command in config.g.
        • MiRundefined
          MiR
          This is the code created by "Grbl Laser" Postprocessor:
          (1001)
          G90 G94
          G17
          G21
          (2D-Profil1)
          G54
          G0 S255 M4
          G0 X24.9 Y0.3
          G1 Y24.9 F1000
          G1 X0.1
          G1 Y0.1
          G1 X24.9
          G1 Y0.3
          (2D-Profil2)
          G0 S50 M4
          G0 X62.5 Y12.5
          G3 X37.5 Z0 I-12.5 F1000
          G3 X62.5 I12.5
          G1 S0
          M30
          from Duet Doku I see that
          G94 Set units per minute feed rate mode is missing but I guess that is ok as mm/min is default for Duet
          G17 Select the XY plane (for arcs) (maybe also does not matter)
          Spindle on is done with G0 S255 M4
          Spindle off is done by G1 S0, not sure if a M5 is needed here or not
          M30 is the only strange candidate,
          for grbl it is
          M30 Program Pause and End
          on Duet it is
          M30: Delete a file on the SD card
          but propably also ok because no file parameter is given.
          I will try that code early next week, my Laser is not where I am right now...
            I thought that grbl and Smoothieware both used the S parameter on G1/G2/G3 commands to set the laser power?
            • MiRundefined
              MiR
              They do it in Fusion 360, but only for turning the laser off 8-( :
              But this is easy to fix with a custom Postprocessor.
              G0 S255 M4
              G0 S50 M4
              G1 S0
              also in Fusion change is quite low as you can only define one power setting per action.
              Other tools like laserweb use the S parameter in a much more aggressive way for laser raster (grbl):
              G1 X0.10 Y0.10 S0.0000
              X0.20 S57.4706
              X0.40 S57.8562
              X0.60 S58.2353
              for smoothieware it uses a value between 0 und 1.0 for S :
              X0.20 S0.5765
              X0.40 S0.5739
