    New Duet Web Control 1.14a and RepRapFirmware 1.17b-ch
    Firmware installation
    • chrishamm
      chrishamm administrators last edited by
      I have released DWC 1.14a on GitHub, see https://github.com/chrishamm/DuetWebControl. This new DWC version fixes a few minor problems and introduces new indicators to display the probe points on the 3D visualisation. Here the full changelog for this DWC version since v1.14:
      Implemented interactive probe point indicators on bed visualisation
      Preparations for different color schemes in 3D view
      Allow users to specify 0 as webcam update interval to request the source file only once
      Changed wrong title description for M117 option on the settings page
      Bug fix: "Download G-code" wasn't working in subdirectories on the Duet WiFi
      Bug fix: DWC pretended no file was being printed while a tool change was being performed
      Bug fix: Don't use max values from heightmap.csv because they can be wrong
      Bug fix: If tool macro options were specified and a tool was deselected, the web interface didn't send the right P-parameter
      Bug fix: After a 'T' status code was received, the status label didn't turn grey in Idle mode any more
      Along with this I have released v1.17b of my firmware fork. It includes dc42's latest firmware improvements and implements a new 'P' parameter for T-codes to specify which tool macros shall be run. That means with my firmware fork you can now skip certain macros like tpost*.g when tools are being changed via the web interface (see Settings -> User Interface). Here the full changelog since 1.17a-ch:
      GCodeBuffer diagnostics includes machine states
      GCodeInput for HTTP+telnet invoke diagnostics via M122 (in case the GBs are blocked)
      Implemented P-parameter for T-codes to specify which macros shall be run
      Added 'T' status character for the web interface to indicate tool changes
      Z probe modulation signal is now driven high only during probing move for Z probe types 4 upwards (thanks dc42)
      Bug fix: Grid M-codes were incorrectly queued
      You can find precompiled firmware binaries here: https://github.com/chrishamm/RepRapFirmware/tree/dev/Release
      Duet software engineer
      • DjDemonD
        DjDemonD last edited by
        If after installing this via the web interface I can no longer access the web interface what is the likely cause?
        EDIT- A reboot of the machine solved it.
        www.precisionpiezo.co.uk
