    My Duet Ethernet is detected as Duet Wifi.
    Firmware installation
    • SEUTec
      SEUTec last edited by SEUTec
      Hi:
      My Duet Ethernet is detected as DuetWifi, after firmware update.
      And do not connect to the local net.
      M115 command returns:
      FIRMWARE_VERSION: 2.02RC2(RTOS)
      ELECTRONICS: Duet WiFi 1.02 or later
      I think this is the cause of error when reading the M552 command in the config.g
        The Ethernet module has 2 rows of header pins that plug into socket strips on the Duet main board. The symptom you describe indicates that one of the pins is not connecting, probably because of a bad solder joint on either the pin header or the socket. It's the front left pin as viewed from the edge of the Duet.
        • SEUTec
          Hi dc42:
          Problem solved.
          I have found 2 poor solderings in Ethernet module, RX, and TX pins.
          Thank you very much for your support.
