    Change Filament fails
    Firmware installation
    • zerspaner_gerd
      zerspaner_gerd last edited by
      Why does the direct filament switch over DWC
      fail with this error:
      Error: M701: Unload the current filament before you attempt to load another one
      When I first unload and then load it works
      Here are my macros
      Change Filament fails.zip
      Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
      • zerspaner_gerd
        I still could not find a solution?
        DWC sends the following code:
        T0
        M702
        M701 S"GreenTEC black"
        M703
        After unloading comes this error:
        Does nobody else have a problem with that? (Affects only the direct filament change via DWC)
          Chrishamm is the expert on both filament management and DWC, so I have asked him to reply.
          • chrishamm
            chrishamm administrators last edited by
            To me it looks like M702 completes before it is actually finished, so M701 is called out-of-order which generates this message. We will investigate why this is happening.
            Duet software engineer
