    Maestro firmware and configuration guide
    Firmware installation
    • sinnedwrong
      sinnedwrong last edited by
      New here and proud possessor of a new Duet Maestro which came with FIRMWARE Version 2.02RC3. However the configuration tool doesn't have this version in the drop down. I'm building a second Ormerod 2. Looking at the config.g files for "1.20" and "1.21 and later" they are identical. Can I use these with 2.02RC3 to get started, should I go back to Firmware version 1.21 or how should I proceed?
      I'm happily connected via a fixed IP and keen to move on.
      Dennis
      sinnedwrong 1 Reply Last reply Reply Quote 0
        You can choose 1.21 and later and start from there.
        https://duet3d.dozuki.com/c/Duet_2_Maestro
        The documentation for the Maestro is largely the same as for the Duet2Wifi and Ethernet.
        • sinnedwrong
          sinnedwrong @sinnedwrong last edited by
          @sinnedwrong Thanks, Using V1.21 it generates M201 X500.00 Y20.00 Z250.00 E250.00 and
          the Y axis very slowly.
          I note the original config file had M201 X1000 Y1000 Z1000 E1000 i.e the X and Y accelerations are the same. On the axis page of the configuration tool the accelerations for Y is 20mm/s which agrees with the config.g file.
          My original Ormerod 2 running RepRapPro firmware has M201 X500 Y500 Z15 E500
          Should I change the Y value, if so to what?
          Dennis
          • Veti
            Veti last edited by
            duet uses mm/min instead of mm/sec. so multiply those numbers by 60
            • sinnedwrong
              From the Duet G code page: https://duet3d.dozuki.com/Wiki/Gcode
              M201: Set max acceleration
              Parameters
              Xnnn Acceleration for X axis
              Ynnn Acceleration for Y axis
              Znnn Acceleration for Z axis
              Unnn Acceleration for U axis
              Vnnn Acceleration for V axis
              Wnnn Acceleration for W axis
              Ennn Acceleration for extruder drives
              Example
              M201 X1000 Y1000 Z100 E2000
              Sets the acceleration that axes can do in mm/second^2 for print moves. For consistency with the rest of G Code movement this should be in mm/(minute^2), but that gives really silly numbers and one can get lost in all the zeros. So for this we use seconds.
              • Veti
                Veti last edited by
                you are right. acceleration is mm/s^2
                and the default values 20 for y is very low. this might be a bug.
                  dc42 administrators @Veti last edited by dc42
                  @veti said in Maestro firmware and configuration guide:
                  I agree, and we will change the default. I suggest you increase the Y value in the M201 command to 500, perhaps higher when you know what the printer is capable of.
