    Haq XY
    Firmware developers
    15.3k
      I have a new internal build supporting the generalised CoreXY kinematics, but I've not had time not run a print using it yet.
      Haggan90undefined 1 Reply Last reply Reply Quote 0
      • Haggan90undefined
        Haggan90 @dc42
        @dc42 That sound great! If you want me to test it I would happily do so 🙂 I got the machine with the schematics described in the first post ready to go 🙂
          I've put a very early beta at https://www.dropbox.com/s/fyvibzm0zl92hiy/Duet2CombinedFirmware.bin?dl=0. Sending M669 K11 should put it in MarkForged mode. If you want to set the movement matrix by hand you can use M669 K0 X1:-1 Y0:1 instead.
          Please test it with great care and low motor current. In particular, the homing behaviour is untested.
          • Haggan90undefined
            Haggan90 @dc42
            @dc42 Im fiddling with it now 🙂
            Maybe a dumb question, but is K0 the X axis? maybe K1 is Y axis?
            In this case, if I just activate Markforged by putting M669 K11 in the config file then X becomes Y and Y becomes X.
            When Y is moving both X and Y need to move, but when X is moving only X needs to move.
            Now its the other way around 😃
              Try this: M669 K0 Y1:-1
              I used the diagram at https://hackaday.io/project/19543-haq-xy/details. So the X motor should just affect X, and the Y motor should affect X and Y.
              • Haggan90undefined
                Haggan90 @dc42
                @dc42 Woho! It worked! 😃
                The homing is a bit weird thoug 😛
                How should I proceed if I want to add another X axis?
                  What is weird about the homing? You will need to home like a CoreXY, see the wiki page on configuring RRF for CoreXY.
                  To add another axis, create a U axis using M584, then use the M669 XYZU parameters to define the matrix you need for the motion. The X, Y, Z etc. parameters of M669 define the rows of the matrix. The rows are the axes, the columns are the motor movements needed to move those axes. Sending M669 without parameters will print the current matrix.
                  At a guess, if the mechanics of U are similar to X, you would need:
                  M669 K0 Y1:-1:0:-1
                  As we started with Cartesian kinematics (K0), any rows you don't specify will just have a 1.0 in the diagonal element.
                  Haggan90undefined 2 Replies Last reply Reply Quote 0
                  • Haggan90undefined
                    Haggan90 @dc42
                    @dc42 Well, first of all I think both the Y motor and all 3 Z motors are going the wrong way, but thats more my fault I guess 🙂 but if I just change the positon in the Y/X home files I could get them to home correctly, but its very buggy and somethines everything just freaks out and goes superfast.
                    So do I need to set the config file to run corexy before I add the M669?
                    Aha I see!
                    But, if I run just one of the extruder heads in Y/X, will the second stay at its home position or will it just run diagonally along?
                    • Haggan90undefined
                      Haggan90 @dc42
                      Holy crap, I think I got it to work 😄
                      Btw, if I use M564 S0 H0 and after that tried to home axis, may that interfear with the homing?
                      M669 K0 Y1:1:0:1 ; set Y to react with X1 and U6
                      M584 Z2:5 U6 ; set 3 Z drivers and U6 (second extruder head)
                      M569 P4 S1 ; Drive 4 goes forwards
                      M569 P5 S0 ; Drive 5 goes backwards
                      M569 P6 S0 ; Drive 6 goes backwards
                        I'm glad you got it working.
                        M564 H0 S0 will not affect the G1 S1 and G1 S2 commands in homing files. It only affects regular G0 and G1 moves.
                        BTW, are you the author of the post at https://hackaday.io/project/19543-haq-xy/details ?
                        • Haggan90undefined
                          Haggan90 @dc42
                          @dc42 hmm ok.. there's definalty somethubg wrong with my homing then. As I said before, sometimes it works perfect and other times, for example, the Y axis just plunge into the endstop and agter I cant move it.
                          No the author is Haqnmaq, iv'e talked to him about this project and he was exited as well 🙂
                          I think this could be a really neet solution for a idex printer.
                            If you home just X or just Y, does that work reliably?
                            • Haggan90undefined
                              Haggan90 @dc42
                              @dc42 Sometimes. But let's say I manage to home Y, if I then move Y and then tried to home it again it will most likley not work as planned.
                                dc42 administrators @Haggan90
                                @haggan90 said in Haq XY:
                                Do you mean that it sometimes ignores the triggering of the Y endstop switch? Are you certain that you have the X and Y endstop switches connected to the right connectors?
                                Please post your homey.g file.
                                • Haggan90undefined
                                  Haggan90 @dc42
                                  @dc42 Yes, but I dont have the endstops for Z and U connected yet so I can't do the homeall.g.
                                  This is the homey.g
                                  G91 ; relative positioning
                                  G1 S1 Y555 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                  G1 Y-10 F1000 ; go back a few mm
                                  G1 S1 Y555 F360 ; move slowly to Y axis endstop once more (second pass)
                                  G1 Z-5 F6000 S2 ; lower Z again
                                  G90 ; absolute positioning
                                  • Haggan90undefined
                                    Haggan90
                                    So i've added the endstop to my U axis, and added a homeu.g folder (not sure if I supose to?)
                                    But I can't home U... I have U motor and endstop connected to the duex2.
                                      Yes you do need a homeu.g file. The U endstop switch must be connected to the E0 endstop input.
                                      • Haggan90undefined
                                        Haggan90 @dc42
                                        @dc42 Ok!
                                        But when I try to home U nothing happends, only Z goes down 5mm and nothing more.
                                          Have you tested the au endstop? https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Test_endstop_switches
                                          • Haggan90undefined
                                            Haggan90 @Haggan90
                                            @haggan90 Got this fixed now, now homing of U works 😃
                                            But everything is still very buggy.. is there something wrong with my homey.g ?
