    Haq XY
    Firmware developers
    15.3k
    • Haggan90undefined
      Haggan90 @dc42
      Config.g
      M669 K0 Y-1:1:0:-1 ; set Y to react with X1 and U6
      M584 Z2:5 U6 ; set 3 Z drivers and add one U driver
      M569 P4 S1 ; Drive 4 goes forwards
      M569 P5 S0 ; Drive 5 goes backwards
      M569 P6 S0 ; Drive 6 goes backwards
      M350 U16 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
      M92 U80.00 X80.00 Y240.00 Z1066.67 E420.00:420.00 ; Set steps per mm
      M566 U900.00 X900.00 Y900.00 Z12.00 E120.00:120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 U10000.00 X10000.00 Y10000.00 Z500.00 E1200.00:1200.00 ; Set maximum speeds (mm/min)
      M201 U800.00 X800.00 Y800.00 Z20.00 E250.00:250.00 ; Set accelerations (mm/s^2)
      M906 U1000.00 X1000.00 Y1000.00 Z1000.00 E800.00:800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 U0 X0 Y0 Z0 S1 ; Set axis minima
      M208 U500 X500 Y500 Z750 S0 ; Set axis maxima
      M574 U0 S0 ; set active low endstops
      M574 X1 Y1 S1 ; Set active high endstops
      M574 X1 Y2 S1 ; X home to min. Y home to max. NC microswitches.
      M574 Z1 S2 ; Define Z to use Probe. Home to Min.
      M558 P9 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 9. Not using on XY, but using it on Z.
      G31 P25 X0 Y-57.3 Z0.0 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      ; BLTouch - Heaters
      M307 H3 A-1 C-1 D-1 ; Disable the 2nd Heater to free up PWM channel 1 on the Duex board.
      M563 P0 D0 H1 ; Define tool 0
      homey.g
      G91 ; relative positioning
      G1 S1 Y-550 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 Y-10 F1000 ; go back a few mm
      G1 S1 Y-550 F360 ; move slowly to Y axis endstop once more (second pass)
      G1 Z-5 F6000 S2 ; lower Z again
      G90 ; absolute positioning
      homex.g
      G1 S1 X-550 F2500 ; move quickly to X axis endstop and stop there (first pass)
      G1 X10 F1000 ; go back a few mm
      G1 S1 X-550 F660 ; move slowly to X axis endstop once more (second pass)
      homeu.g
      G1 S1 U-550 F2500 ; move quickly to X axis endstop and stop there (first pass)
      G1 U10 F1000 ; go back a few mm
      G1 S1 U-550 F660 ; move slowly to X axis endstop once more (second pass)
      • Haggan90undefined
        Haggan90 @dc42
        @dc42 I've manage to get the homeall.g to work now byt homing Y first, then X and then U (all independently).
        But I have encountered another problem.
        When I try to run G29 both the X and U tries to move, when I only want X and Y to move.
        U just crashes into the endstop.
        config.g looks like this
        M558 P9 H5 F500 T6000 ; Set Z probe type/mode 9.
        M557 X50:480 Y60:480 S50 ; define mesh grid
        ; BLTouch - Heaters
          dc42 administrators @Haggan90
          @haggan90 said in Haq XY:
          Can you tell me which sequence didn't work? I still want to sort it out. You should be able to home the axes in any order, even simultaneously to begin with.
          Do normal X, Y and XY moves work correctly? In particular, Y and XY moves should turn the U motor so that the U axis doesn't move. The only time that commands shouldn't move just the axes you mention is when you send G1 S2 moves, because they are individual motor moves.
          Also, if you send a G30 probing move such as G30 P0 X100 Y100, does it just move X and Y to 100, or does U move too?
          Haggan90undefined 1 Reply Last reply Reply Quote 0
          • Haggan90undefined
            Haggan90 @dc42
            @dc42 said in Haq XY:
            For some reason I can't home all again... now when Y tries to home first both X and U moves towards their endstop (at a much lower speed then Y). This is my homeall.g
            G1 S1 Y-550 F2500 ; move quickly to Y axis endstops and stop there (first pass)
            G1 Y5 F1000 ; go back a few mm
            G1 S1 Y-455 F660 ; move slowly to Y axis endstops once more (second pass)
            G1 S1 X-550 F2500 ; move quickly to U axis endstop and stop there (first pass)
            G1 S1 X-550 F660 ; move slowly to U axis endstop once more (second pass)
            G1 S1 U-550 F2500 ; move quickly to U axis endstop and stop there (first pass)
            G1 S1 U-550 F660 ; move slowly to U axis endstop once more (second pass)
            G1 X35 Y65 F6000 ; go to first bed probe point and home Z
            G1 S2 Z5 F100 ; lift Z relative to current position
            If I just toggle Y/X/U every axis works perfect, when I move Y for example both U and X are perfectly still in x/u axis.
            And when I move only X/U the Y axis is perfectly still.
            Nothing hapends at all if I send G30 P0 X100 Y100, but If I only send G30 (after all axis has been homed) everything just seems to screw up.. I will film it and post a video link soon!
            • Haggan90undefined
              Haggan90
              Sometimes It seems to work with the home all, if I just do it as soon as I start the printer. But if I have moved any axis before, this happends: https://www.youtube.com/watch?v=hShrS0JAh68
              And this is what happends if I first manually home all axis and the use G29 (mesh grid): https://www.youtube.com/watch?v=Vcpx7KPqJXw
              • Haggan90undefined
                Haggan90
                Config.g
                M208 U550 X550 Y500 Z750 S0 ; Set axis maxima
                M557 X30:530 Y65:490 S50 ; define mesh grid
                ; BLTouch - Heaters
                • Haggan90undefined
                  Haggan90
                  This is with no homing, just moving each axis: https://www.youtube.com/watch?v=kP_eEowGYOI
                  • Haggan90undefined
                    Haggan90
                    I just tried to disconnect the U stepper and same things happends, all code as well.
                    I'm really out of ideas now, do you have any sugestions?
                    • Haggan90undefined
                      Haggan90
                      @dc42 I'm beginning to think that there might be some bug in the firmware with the matrix you made, as It works great when using the toggle to move each axis but as soon as I try to move any at the same time everything just gets messed up.
                        The movement in that video looks OK to me, assuming that the print heads moved in the directions you commanded.
                        What happens when you try to move axes simultaneously, e.g. to do diagonal moves?
                        • Haggan90undefined
                          Haggan90 @dc42
                          @dc42 If I just send G1 Y50 X50 it seems to work as it should, but I can't home any axis after (like in the homall video)
                          • Haggan90undefined
                            Haggan90
                            @dc42 I just tried to change the M669 from K0 to K1 without any luck, same problems. On the plus side of this I'm starting to get a good hang of some gcode 😛
                            Do you think there might be some bug in the firmware?
                              Quite possibly, and I already have it on my list to simulate your machine on my bench. I may have time to do this tomorrow.
                              • Haggan90undefined
                                Haggan90 @dc42
                                @dc42 oh that's awsome! Let me know if I can do something to help 🙂
                                  In your M584 command, you forgot to redefine the extruder drives. So your extruder settings are messing up your axis settings. Please fix that and try again.
                                  EDIT: I corrected that, also I configured a U endstop switch. As far as i can tell, it is working. I'm using a slightly later version of the firmware, it's at https://www.dropbox.com/s/fyvibzm0zl92hiy/Duet2CombinedFirmware.bin?dl=0.
                                  • Haggan90undefined
                                    Haggan90 @dc42
                                    I fixed the M584 to this: M584 X0 U6 Y1 Z2:5 E3:4
                                    The homing seems to work as before, but the same thing happends if I try and run G29 (reffering to my last video).
                                    I do have an endstop for U.
                                    • Haggan90undefined
                                      Haggan90
                                      IF I change the homeall.g to this, the homeall doesen't work at all If either X or U endstop is hit before I start the homing. I need to home all axis by them self.
                                      G1 S1 Y-550 X-550 U-550 F2500 ; move quickly to Y axis endstops and stop there (first pass)
                                      G1 Y5 X5 U5 F1000 ; go back a few mm
                                      G1 S1 Y-550 X-550 U-550 F660 ; move slowly to Y axis endstops once more (second pass)
                                      • Haggan90undefined
                                        Haggan90
                                        I just found out another strange thing..
                                        If I home all axis, my home position is X35 U0 Y65 Z0, which it should be.
                                        But if I then do another homeall from that position I get all kinds of diffrent values, like X-95 Y65 U0 Z0.
                                        One can clearly see the U and X axis acting strange when I try to do a second homeall, the U crashes into the endstop and so on.
                                          Please read the wiki page on configuring a CoreXY printer. Note the bit where it says that you can do initial XY homing concurrently in homeall.g, but then you must home X and Y individually after that. In your case you should be able to do initial homing of XYU concurrently (which will stop when any one of XYU is homed), then you can home Y by itself and then X and U concurrently.
                                          If you still have problems after fixing that, post your latest config.g and homeall.g file.
                                          • Haggan90undefined
                                            Haggan90 @dc42
                                            @dc42 I just tried that and as soon as Y endstop hits everything just stops.
                                            this is my homeall.g:
                                            G1 S1 Y-550 U-550 X-550 F2500 ; move quickly to Y axis endstops and stop there (first pass)
                                            G1 S1 y-550 F2500 ; Home Y seperate
                                            G1 S1 X-550 U-550 F2500 ; Home X and U seperate
                                            G1 Y5 X5 U5 F2000 ; Go back 5mm on all axis
                                            G1 S1 Y-10 F600 ; slowly home Y
                                            G1 S1 U-10 X-10 F600 ; Slowly home X and U
                                            This is my config.g:
                                            M584 X0 U6 Y1 Z2:5 E3:4 ; set 3 Z drivers and add one U driver
                                            M574 U1 S0 ; set active low endstops
                                            M558 P9 H5 F500 T4000 ; Set Z probe type/mode 9.
                                            ; BLTouch - Heaters
