    Maestro halted after macro launched on DWC
    Firmware installation
    • pabomanundefined
      paboman
      The machine was printing from SD card, I launched a macro calling M122 to see if any hiccups are occuring, after this the DWC stopped responding (host unreachable) so I went to the Panel Due to see if the network module was still online but as soon as I touched the Macro tab button the machine stopped.
      I will try to reproduce this error
      RepRapFirmware for Duet 2 Maestro version 2.02RC4(RTOS) running on Duet Maestro 1.0
      Board ID: 08DAM-9F9DA-MWNS8-6J1DG-3SN6K-K406X
      Used output buffers: 1 of 20 (14 max)
      Static ram: 21428
      Dynamic ram: 96812 of which 0 recycled
      Exception stack ram used: 212
      Never used ram: 12620
      Tasks: NETWORK(ready,456) HEAT(blocked,1300) MAIN(running,3672) IDLE(ready,200)
      Owned mutexes:
      Last reset 00:00:21 ago, cause: software
      Last software reset at 2018-11-22 20:00, reason: Stuck in spin loop, spinning module GCodes, available RAM 12172 bytes (slot 0)
      Software reset code 0x4043 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0400f80f BFAR 0xe000ed38 SP 0x20000f1c Task 0x5754454e
      Stack: 00440d4f 00444830 21000200 00000004 00000000 00000004 00444a2d 200046dc 00440d4f 00000001 00000004 2001c354 00000004 2001c354 000069c4 00000004 00441075 00000004 00000000 00000000 00419f2f 00441015 00745fff
      Error status: 0
      Free file entries: 9
      SD card 0 detected, interface speed: 15.0MBytes/sec
      MCU temperature: min 39.3, current 39.5, max 39.9
      Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: standstill, read errors 0, write errors 1, ifcount 22, reads 857, timeouts 0
      Driver 1: standstill, read errors 0, write errors 1, ifcount 22, reads 857, timeouts 0
      Driver 2: standstill, read errors 0, write errors 1, ifcount 22, reads 857, timeouts 0
      Driver 3: standstill, read errors 0, write errors 1, ifcount 180, reads 857, timeouts 0
      Driver 4: standstill, read errors 0, write errors 1, ifcount 171, reads 857, timeouts 0
      Driver 5: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 864
      Driver 6: ok, read errors 0, write errors 0, ifcount 0, reads 0, timeouts 863
      Date/time: 2018-11-22 20:01:12
      Slowest loop: 4581228.50ms; fastest: 0.06ms
      I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: none
      Bed heaters = 0, chamberHeaters = -1 -1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Stack records: 1 allocated, 1 in use
      Movement lock held by null
      http is ready with "M122" in state(s) 0 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      lcd is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 7.61ms; fastest: 0.03ms
      HTTP sessions: 1 of 8
      Interface state 5, link 100Mbps full duplex
      === Filament sensors ===
      Extruder 0 sensor: position 0.00, no data received, no calibration data
        Were you able to reproduce it?
        pabomanundefined 1 Reply Last reply Reply Quote 0
        • pabomanundefined
          paboman @dc42
          not the same way, but yesterday i paused the print to change filament and the DWC become unreachable again.
          also the maestro freezed, I was unable to resume the print
