    PCB through hole resistor soldering
    Off Topic
    • wilrikerundefined
      wilriker
      I have - for the first time - to solder some resistors to a PCB using through holes. So far I only had to solder something like pin headers that already have the correct leg length. Resistors on the other hand have a lot longer legs.
      My question now is: should I trim the legs before or after soldering? Does it make any difference at all? I tried to do a quick research about it but failed to get a good answer.
      Manuel
      My Tool Collection
      • dragonnundefined
        dragonn
        After soldering, it makes soldering it much easier. When you cut before you can easy make a mistake and cut it to short.
        • OBELIKSundefined
          OBELIKS
          After, so you can bend the legs when they are in the hole and component stays put when you turn the board around 😉
          P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
          Original Prusa i3 MK3S
          • wilrikerundefined
            wilriker
            Thanks a lot! 👍
            Together with a response I got offline (after posting this) this makes three times the same answer. I will go with cutting after soldering then. 🙂
            P.S.: Building a small oscilloscope here (JYEtech DSO138mini). 😁
            Manuel
            My Tool Collection
