    Duet webcontrol extrem slow after upgrading
    Firmware installation
    • KevinO
      KevinO last edited by KevinO
      I just upgraded my Duet Wifi from 1.20 to 1.21. For this I upgraded the duetwebcontrol to 1.22.3 (over the Duetwebcontrol) and since then the Webcontrol is extremely slow ...
      I've already taken the printer from the power and restarted, but nothing has changed. In addition, I have listed an infinite number of macros that repeat constantly.
      right now it says:
      Firmware version: 1.20
      Wifi Server Version: 1.21
      Web Interface Verision: 1.22.3
      someone had ever had these mistakes or does anyone know how I can eliminate it?
      thank you very much 🙂
        I think you should try updating the firmware again since it doesn't look like it applied. If it doesn't work again, I suggest updating your IAP files since you may be using a version from an older release.
        I would suggest updating the files again one at a time from this release, starting with the IAP files. https://github.com/dc42/RepRapFirmware/releases/tag/2.0
        If that works for you, I would suggest continuing on to https://github.com/dc42/RepRapFirmware/releases/tag/2.01 to get the latest stable release.
        • KevinO
          thank you very much 🙂 i think there went something wrong during the update... i erased everything and did an clean install and right now iam on 2.02 and everything works fine 🙂
