    SOLVED Dug myself into a hole with firmware - need help
    Firmware installation
    • deckingmanundefined
      deckingman
      Long story short, While investigating something I thought I'd try reverting back to a firmware version earlier than 1.17. I found 1.15e on my PC so uploaded that. Now I want to go back to some flavour of 1.17 but can't. When I try, I get this:
      Can't rename file or directory /sys/DuetWiFiFirmware-1.17rc3.bin to /sys/DuetWiFiFirmware.bin
      Can't delete file /sys/DuetWiFiFirmware.bin
      Help please.
      • Dougal1957undefined
        Dougal1957
        I to have fallen into that trap it is cos the DWC you have is not compatible with older FW you will need to use the Recovery procedure using USB and SaMba
        Doug
        (There has been a recent thread about recovering a seemingly dead DuetWiFi)
        This is what you need try Recovery Proc 3
        https://duet3d.com/wiki/Updating_main_firmware
          See backup procedure #1 in the firmware update instructions, https://duet3d.com/wiki/Updating_main_firmware#Backup_procedure_.231.
            deckingman
            Thank you. Procedure#1 did the job (once I realised that I had to rename the firmware file to just plain DuetWiFiFirmware.bin)
            • InSanityundefined
              InSanity
              Might be wise to have some sort of confirmation/warning when trying to downgrade firmware.
              Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
