Disable the interpolation only on the extruder?
Firmware installation
  • undefined
    Neotko
    I want to disable the interpolation only on the extruder and on the wiki it says
    "Inn Enable (nn=1) or disable (nn=0) microstep interpolation mode for the specified drivers, if they support it. "
    So I assume this would do?
    M350 E16 I0 ; Disable interpolation on extruder
    M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation for XYZ
    Is this possible or it's an all on/off trigger?
    • undefined
      You have it correct. You just need to define the extruder on a seperate line with I0.
      • undefined
        Neotko
        Thank you!
        1 out of 3
