    [explained] not BUG on temperature settings
    Duet Web Control wishlist
    1018
    • c310
      c310 last edited by c310
      Hi! i use DWC 1.21.1
      there are temperature controls (see below)
      if bed is OFF and i type in some temperature (let say 75) and press enter it automatically switches heatbed on
      if i do the same in Tool 0 (from off or standby states) after "enter" it does not start heating up. 😞
      please fix this. many thanks
      fcwilt 1 Reply Last reply Reply Quote 0
      • fcwilt
        fcwilt @c310 last edited by
        @c310 I believe it is working as designed since you can have more than one tool.
        Simply setting the temperature and activating that tool might not be appropriate.
        However since there is only one bed it is safe to activate it.
        Printers: A FT-5 with the 713 upgrade bits. A custom MarkForged style. A small Utilmaker style and a CoreXY from kits. Various hotends. All with a variety of Duets (2 and 3) running 3.3.0
          That's correct, in RepRapFirmware setting a tool temperature is a separate operation from activating the tool.
          • c310
            c310 last edited by
            ok, perhaps if there is only one tool, it can activate than
              dc42 administrators @c310 last edited by
              @c310 said in [explained] not BUG on temperature settings:
              Users of printers with only one tool often put a T0 command at the end of config.g.
              Danal 1 Reply Last reply Reply Quote 0
              • Danal
                Danal @dc42 last edited by Danal
                @dc42 said in [explained] not BUG on temperature settings:
                Because NOT having any tool active causes a lot more weird things than temp not "activating itself". Like no moves, etc. Therefore... very important to have an "active" tool, even on printers that only have one... in short: Last command in /sys/config.g should be "T0".
                • DocTrucker
                  DocTrucker last edited by
                  Wouldn't it be better to have T0 in your start gcode, or setup macro if you have it?
                  Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
                  dc42 wilriker Danal 3 Replies Last reply Reply Quote 0
                    dc42 administrators @DocTrucker last edited by
                    @doctrucker said in [explained] not BUG on temperature settings:
                    Yes, that's what I do.
                    • wilriker
                      wilriker Moderator @DocTrucker last edited by
                      But slicers (at least some of them) will heat up to temp before calling the start codes. So in case there is no tool selected wouldn't this fail then?
                      Manuel
                      My Tool Collection
                        dc42 administrators @wilriker last edited by
                        @wilriker said in [explained] not BUG on temperature settings:
                        That's correct; although if you put your own temperature-setting commands in the start GCode, most slicers will spot this and not insert their own.
                        To help work around the problem of tools not being selected, if M109 is received with no tool selected, RRF automatically selects the tool referred to in the M109 command if there is one, or the lowest-numbered tool if there isn't.
                        wilriker 1 Reply Last reply Reply Quote 0
                        • wilriker
                          wilriker Moderator @dc42 last edited by
                          They would - if my start code would not be just a
                          M98 /sys/print_start.g
                          OK, that one might come in handy then, thanks! 👍
                          Manuel
                          My Tool Collection
                          • Danal
                            Danal @DocTrucker last edited by
                            As vs having T0 at the end of config.g?
                            Well... slicer provided start G-Code would be an OK place for T0, as long as you never issue any commands, say with DWC, prior to printing something...
                            IMHO, config.g covers more ground in terms of typical "use cases". ("User Stories"?)
                            • DocTrucker
                              ...but it leaves the heater permanently active.
                              I've never had T0 in my config and it's caused me no trouble.
                                Phaedrux Moderator @DocTrucker last edited by
                                @doctrucker what's wrong with leaving it active? It's still off as long as no temp is set.
