    Suggestion for Macro Screen
    Duet Web Control wishlist
    • gnydickundefined
      gnydick
      When in the macro section, please make it so clicking the file opens the editor, just like in the settings editor. Makes no sense to ask you if you want to run the macro while on that screen since macros are by definition shortcuts, which are meant to be used to speed up some other process, specifically in this, most likely while on the machine control page.
        I wouldn't mind having the pop-up window if it had three option buttons: run, edit, cancel.
        The confirmation aspect is important though because running a macro at the wrong time can have damaging consequences.
